Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: rear brakes not working
    If fluid is coming out and coming out clear than I would doubt the caliper is stuck. A stuck caliper is almost always due to corrosion and clear fluid is unlikely to come from a rusted up caliper. Maybe a bad re-man unit?
    If there is pressure at the caliper the master and ABS aren't suspect. The caliper slides would need to be seriously seized to prevent ANY movement(you can turn the wheel by hand with brake applied) which would usually result in a dragging brake.
    Is this car new to you? The probability of what you are describing is very low unless some one has botched something or perhaps the car was unused for a long time while in a corrosive environment.
    Clear fluid tells me it was recently bled though, what is the rest of the story?
    Regardless, if there is adequate pressure to the caliper a fresh caliper and hardware ought to solve your troubles.
    Sep 2007
    Seattle, WA
    How worn are the pads & rotors? Could you have possibly wore them down far enough that the caliper has doesn't have enough travel to apply pressure to the rotor anymore?
    Aug 2008
    London, UK
    Quote Originally Posted by russiankid View Post
    You will notice that it will be hard to get the guides out if they're seized. If they are seized, I advise you to get new ones.
    and they are not cheap. I replace my front ones which were quite badly pitted (nb: brakes were fine, I was replacing all the suspension and decided to the disc's and pads at the same time) and they were 15 gbp each, so 60 gbp for the front
    One thing to be super carful of is the brake carrier (number 3 here) that the guides screw into. It could have been I was unlucky but when I tried to put the guides back into the carrier the thread in the carrier was completely destroyed. I didn't have any trouble taking them out, and was careful handling them but this still happened. I wasn't too pissed until I saw the price at the dealer for a replacement which was far toooooo much money. Long story short, I got the carrier Heli-Coiled for about 30 gbp and it's been fine ever since.
    hth
    sal
    If the guides were seized{not likely} then the caliper piston would still push the brake pad against one side of the rotor and wear one pad down rapidly.
    Either the caliper piston is seized(unlikely) or the guides are seized.
    Not possible, the caliper piston will keep on going until it comes out of the bore and fluid goes everywhere, you can't wear one down far enough that the caliper won't apply pressure to the rotor.... if that does happen as i said above the piston pops out of the bore and you suddenly lose one brake circuit completely.
    Quote Originally Posted by bubba966 View Post
    columbus, ga.
    Default daily driver
    Car has been daily driven for two years. I only drive 1.5miles to and from work. Not really sure how long they have not been working or if they ever have. Only time I noticed was stopping on a downhill on a gravel driveway and car would slide a little. Thought that was due to the loose control arms on front end which have since been replaced. Was not able to pull off brakes yesterday due to the snow here. Will pull off and check calipers tonight and also guide bolts. Thanks everyone for your input & help. Will post back tommorow with results.
  1. Rear brakes click
    Last Post: 12-03-2007, 10:31 AM
  2. Smoking rear brakes...literally. Need help with causes.
    By bimerguycw in forum 5 Series BMW
    Last Post: 10-19-2007, 11:37 PM
  3. question on rear brakes
    By ejhiggins in forum 5 Series BMW
    Last Post: 01-13-2005, 11:38 PM
  4. E32 750 rear brakes on E34 Bruno??
    By mholbrook in forum 5 Series BMW
    Last Post: 07-02-2004, 01:01 PM
  5. Rear brakes locking up
    By mjfeeney4 in forum 5 Series BMW
    Last Post: 02-28-2004, 07:50 AM
