1995 E34, M50 Auto with 205K
The ABS light came on some time ago, brakes are fine, fluid is fine. Other than going to the dealer for a scan any ideas?
The two rear tires were just changed yesterday, they were kind of bald, the light is still on.
on mine the cause was a charging problem (battery or alternator) the abs master is on the same circuit.
use obc test #9 to confirm you are getting at least 13V when running.
not yet, i'm waiting for spring (it's still -14'c here) to do the alt/starter/bat+ cable swap.
i'm certain my problem is in there somewhere, i think either the alternator cable or the connector.
for now i just keep the obc on test9 and make sure i keep it above 13v all the time. it's rare that i can use the rear defrost which sucks but i can live with it.
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
thanks for the pics.
i replaced the batt/chassis/engine grounds too...
this looks like the old alternator pos wire- you had that replaced? to the connector at the starter?
sorry if i'm pointing out the obvious but the alternator D+ ring terminal/wire is busted in that photo... that wasn't it either?
i changed both ring terminals but not the whole wire yet... it's ready for a warm spring day...
oops. i posted the old alt. pix. sorry. I had that wire replaced too alt to starter. charging is still bad when full load.I might end up getting an alt. again for the FOURTH time!
