Results 1 to 10 of 11
Thread: window motor/regulator repair time
  1. #4
    Apr 2007
    TX
    Quote Originally Posted by Russell View Post
    Thanks. is this gear tooth in the motor or regulator? Half day seems a long time.
    I don't remember those parts, so I'm going to say the motor. The regulator is just a big metal scissors that lifts the window. The motor mounts to the regulator, so you'll swap it out to the new unit.
    The plastic guides that slide within the tracks of the regulator (the one that broke on mine could not be serviced) are usually what break. Make sure you really grease up the tracks before putting the panel back on.
    EDIT -
    Here is a picture of it. You can see one of the white plastic guides at the 8:00 position. That is what broke on mine. If the other ones are broken, I think they can be replaced. If you replace the regulator, and it doesn't come with those guides, order new ones.
  1. Window Motor & Regulator work from sedan to touring?
    By elbasha in forum 5 Series BMW
    Last Post: 02-08-2009, 07:59 PM
  2. Parts compatability E36 & E34 window regulator
    By buzz66 in forum 5 Series BMW
    Last Post: 04-30-2007, 03:14 PM
  3. **** i think my window regulator died
    Last Post: 03-08-2007, 04:20 PM
  4. Replies: 3
    Last Post: 12-06-2005, 11:08 PM
  5. Need help with window regulator
    By NoSpeedLimits in forum 5 Series BMW
    Last Post: 09-07-2004, 09:53 AM
