Not to bring up the obvious, but have you checked your ATF level?
The 5 speed auto box in my 95 525i is acting stry.
When in neutral, park or any gear there is a ticking noise which is apparent when the car is stationery, which is coming from the gearbox. I have gotten underneath the car whilst it has been running and the ticking noise it most apparent from near where the gearbox meets the engine. Somebody said it could be the oil pump in the box maybe??.
The other thing it does is sometimes when i come to a standstill for a second and then accelerate again it doesnt seem to engage a rear, i.e it will creep forward and then tou feel a violent thud and then the car is in gear. This doesnt happen all the time though, and also sometimes when its changing gear it appears to slip, but again this doesnt happen all the time and thirdly, when the car is going into 3rd gear, at brisk acceleration, (i.e entering the motorway) just as it's about to select 3rd, it jumps out of gear (as if youve kicked down) then goes back into 3rd after about 2 seconds and then it will go into 4th????? it does this everytime. any ideas guys??
Mine ticks too and I've heard its the torque converter. I doubt its the cause of your problems, but like xpseedy said check the ATF level.
Sounds low on ATF this is usually the cause of not engaging Drive initially until pressure has been built up.
I thought the 5 speed is "sealed for life", therefore has no dip stick?
1997 e39 523SEi touring.
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
This may not apply since you have 5-speed auto in a 525i. However, I would consider changing fluid and filter.
In the US, the 95 i525i s not a sealed lifetime trany. It is a French made GM 4-speed automatic that use Dexron II, III or VI ATF fluid. In this trany fluid and filter should be changed on a regular basis such as 30,000-40,000 miles. Do not power flush.
There is no trany dipstick so getting the proper fluid level is extra work. If needed do a search on how.
My guess is you have same tranny as me - the 5HP18 a.k.a A5S310Z. If the plate is black it will take Dexron. If its green it will be the life time stuff. The 'creep' could be caused by the selector cable not being adjusted correctly. You just put it in park, undo the bolt/locknut at the end of the cable and push the lever coming out of the gearbox fully forward. Do the same with the selector lever itself. Then retighten. No change may mean the clutch 'A' pack is stuffed. If you are getting a thump when going into D or R, check your idle isnt too high. Max is about 1500rpm when stone cold but mine never goes above 1000rpm anyway. The other symptoms could either be clutch faults or faults in the valve body. First thing I'd do is get codes read. Then I'd drop the oil pan and look for swarf and friction linings in the bottom of the pan. If there is a lot, the tranny may well have had it. The valve body can be dropped with the tranny in the car but if the clutches are shot it means taking it out.
