straighten the unibody? Mine sits lower on the drivers side 2 cm and nothing has helped. I adjusted my rear view mirror to compensate and wont look at the cars stance from front or real.
Hi everyone.
I have problem with uneven suspension on the front left side, it is about 1cm higher than the right side
I installed H&R sport springs with standard shocks and i replaced all spring pads, control arms and thust arms.
Is there any thing that can be done to sort it out or is there something wrong
with my springs.
All car is lower on the driver side after time... it is because we always sit in that position and that spring takes more load and work so it does go lower. The other thing you need to do is make sure the end of the spring actually aligned with the strut housing end... they have an end indentation where the end of the spring sits.
Are the springs correctly seated? A cm is roughly the diameter of the coils, if one were not seated that might explain this.
Try changing to a slimmer spring pad on the higher side? 3mm?
Also, worn out lower control arm bushing will also cause sag.
