well the reason I can not see the battery or check engine light is because they do not light up. I will check Bently book to see if there are bulbs in there that can be replaced or ?
Side Note; not sure what it is called, and was told by dealer that it is only available when you buy the whole wire harness. It is black plastic piece with a metal center and 240 ohms marked on the outside. It is connected on a brown wire, assume a ground. Any idea what this is and if it being broken can be causing some problems? Since we bought this a year ago, I dont recall the batt and engine lights working, but the dealer did say that this piece may mess up the dme. It has been running great up until this recent shutdown. thanks,Joe
