Results 1 to 8 of 8
Thread: Draining Coolant from Engine Block vs Lower Rad Hose
    Ottawa, Ontario, Canada
    Default Draining Coolant from Engine Block vs Lower Rad Hose
    1989 535i M30 engine
    If I replace the lower rad hose does this drain off most of the coolant in the engine block effectively the same as draining the coolant by removing the engine block drain plug (which I haven't located yet)?
    Blair...
    Oldham, England
    Quote Originally Posted by angusbn View Post
    Blair...
    You will get coolant backed up behind the pump and IIRC the drain is lower anyway so you wont empty the block by just removing the hose. The drain on the M50 is under the exhaust manifold so I guess its in a similar spot on yours. Depending on what you want to do, draining the whole lot makes life easier/harder
    Jan 2008
    Quebec, Canada
    To effectively remove ALL the coolant from the system, you need to remove the t-stat and stick a garden hose in the top rad hose and don't stop till the bottom comes out clear water, if you really want you can run the engine for a couple second to let the pump push out all the old coolant.
    BMW E34 1992 525i Touring
    Jun 2006
    Bethesda, MD
    Quote Originally Posted by bad_manners_god View Post
    I would be hesitant to run the pump dry like that, would that really be advisable to get all the coolant out?
    Jan 2008
    Quebec, Canada
    Quote Originally Posted by nirvana19 View Post
    I meant with the hose pumpung fresh water to the pump. never to run it dry
    edit: nevermind I thought you typed M60...
    you can get to the pass side plug easily, flush til clear. Put the plug back in and then figure total volume of coolant and add straight coolant first, then the balance with distilled water.
    Blair...
    East Brunswick, New Jersey
    There is a coolant drain cap on the block. Every engine does.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Default Its a impellar pump, running it dry won't
    hurt it, but it won't help anyway. It won't pull all the water out of the block. The drain plug in the side of the block 3/4 of the way back on the exhaust side is the only way to get it all out.
  1. Replies: 25
    Last Post: 05-08-2010, 03:30 PM
  2. '89 525 Which coolant hose likely to fail first?
    Last Post: 08-28-2009, 11:52 AM
  3. Is this a coolant hose?
    By ScottyWM in forum 5 Series BMW
    Last Post: 07-31-2007, 08:25 AM
  4. 540 engine block coolant drain plugs.
    By 525SEI BRIT in forum 5 Series BMW
    Last Post: 03-16-2007, 07:17 PM
  5. What does this coolant hose do/go?
    By pingu in forum 5 Series BMW
    Last Post: 05-24-2006, 03:29 PM
