Well, I thought maybe cleaning the crank position sensor would have helped but...this morning I'm back to square one.
I've cranked it over for 10 minutes and not even a prayer.
Any ideas would be appreciated![]()
There was no previous indication of any problem....went to start the car yesterday morning and it would just turn over but not fire...checked fuses, all ok....fuel pump inside gas tank is brand new and lots of pressure in the fuel lines. Cranked it over a few more times, nothing... waited five minutes. Tried again and it started, and ran great all day with no indication of any problems, so warm/hot starting is not a problem.
I put in a new ignition coil this morning and turned her over...wouldn't fire...kept trying and nothing. Eventually took the airbox out and cleaned the crank position sensor...tried a few more times, finally on the third try she fires up, and runs great all day starting up fine even after sitting for 4-5 hrs as long as the engine is even a little warm, and I should say it starts without hesitation on both days as long as the engine is even slightly warm.
Any ideas? My parts guy thinks crank or cam position sensor...I'm baffled.
Everything is new, spark plugs, wires, cap, rotor, and now coil.
Originally Posted by islandphile
Thanks Bill...Where are those located and how are they checked??
It's a 1991 e34 auto.
I just took a pic of the fuse box & relays...Is this where I should be looking?
http://www.sounddomain.com/memberpage/392547/4
passenger side. The closest one to the fender is the fuel pump relay...the orange one in the pic here... the white one is the dme or main relay..
To troubleshoot it remove the relay and jumper across it. Frequently just removing and replacing the relay will clean the contacts enough that it will start working again...but if not jumper across the relay and see if the car will start.
Cool man...I'll try that right now!!!
Well...the relays work fine...This is one of those times I just want to take a sledge hammer to it...
I looked on a Bocsh K-Jetronic trouble shooting page for some help.
http://www.forparts.com/techbosKjectronic.htm
Do I have an Aux air valve on the m30 motor? Or a sensor plate? If so where are they and should I check those too?
by the fuel tank... if its running then put the relay back in and have someone crank the engine with the coil wire removed from the coil and held about 1/2 inch away... do you see spark when its cranking... If you do then check for spark from the dist cap to the plugwire by pulling a plugwire on one cylinder where it goes into the cap and holding it about a 1/2 inch away and cranking.. if spark visible there...If the fuel pump is running and you have visible spark then you need to get a noid lite and check the injector harness to see if the injectors are triggering...
