Results 1 to 8 of 8
Thread: Just replaced heater valve and now no heat!
    Default Just replaced heater valve and now no heat!
    I just replaced the heater valve in my '95 525it to try and cure a problem in which the heat was stuck 'on' in the floor vents, but after replacing now I can't get any warm air out of the vents, period. Anyone have any ideas what could have happened? It's a brand new heater valve... not used... Auxiliary pump sounds like it's running normally when I turn the key on...
    Not sure if this is a clue, but I'm only getting 12 volts from pin 1 of the 3 pinned plug that plugs into the heater valve on top. I'm not getting any voltage, whatsoever from the other 2 pins... Is this normal operation?
    Thanks in advance-
    E46 M3
    E30/M50 track car
    E34 525it
    Jan 2008
    Quebec, Canada
    Maybe the system has to be bleed, was any coolant lost changing the heater valve?
    BMW E34 1992 525i Touring
    exactly what I was thinking... cant find my Bently to look at the schematic.
    Quote Originally Posted by bad_manners_god View Post
    Maybe you guys are onto something. I just took the car for another test drive and the heat is working again. I will bleed the system again but I'm also wondering if I need to change the thermostat...
    E46 M3
    E30/M50 track car
    E34 525it
    Only need to change the thermostat when it's broken or for regular maintenance
    Yes but won't a stuck open thermostat also cause symptoms of no or limited heat?
    E46 M3
    E30/M50 track car
    E34 525it
    Jan 2007
    Dayton Ohio
    Bleed then bleed then bleed again. Front end slightly angled up.
    I would change the thermostat in regular intervals of 2-3 years as preventive maintenance, they WILL break anyway, and before you have a overheated cylinder head which costs a lot of money, do yourselves a favour and change the t-stat in certain intervals.They break all after a certain time of thousands of hours bending! I have seen too many broken t-stats.
  1. e34 heater woes - no heat below
    By DaveCN in forum 5 Series BMW
    Last Post: 02-11-2008, 05:33 PM
  2. Replies: 0
    Last Post: 09-03-2007, 09:53 PM
  3. Replaced valve cover gasket -> different car
    By jbourke in forum 5 Series BMW
    Last Post: 04-18-2006, 11:33 PM
  4. Dammit, heater valve didn't fix my heater...
    By Dan in NZ in forum 5 Series BMW
    Last Post: 07-01-2004, 07:01 PM
