Thread: Connector stuck
    Jan 2007
    Dayton Ohio
    Default Connector stuck
    Trying to get a plug on the throttle body out but it is stuck. Anyone have any success with loosing these up. I know you turn the connector about 10 degrees and they spin off. Don't want to break it
    Jan 2008
    Quebec, Canada
    spray it with wd-40 or whatever lube you have and try to give it a sharp twist to break it free. Use a rag/cloth to hold it.
    BMW E34 1992 525i Touring
    Penetrating spray that is safe for plastics and maybe gentle heat from something like a hair drier. These plastic connectors get brittle with age and are even more crumbly when cold. Warm up the plastic to lessen the chances of snapping something off while turning. Good luck
    Jan 2007
    Dayton Ohio
    Will do. Perhaps some silicone spray and a hair dryer. That sounds like the ticket.
    They are available as single item from the dealer, if you break it, but you have to make a pinout tol to get the pics out from the socket. How to make one
    http://www.bimmerboard.com/forums/posts/452021/
    Jan 2007
    Dayton Ohio
    Here is hoping I don't break it.
  1. Removing stuck wheels+stuck lugnuts
    Last Post: 06-02-2010, 09:28 AM
  2. Does anyone know this connector?
    Last Post: 11-03-2008, 09:44 AM
  3. M50 cam vs crank connector?
    By Grantus in forum 5 Series BMW
    Last Post: 03-15-2008, 10:00 PM
  4. Anyone know what this connector is for ?
    By zygoteer in forum 5 Series BMW
    Last Post: 04-03-2006, 05:23 PM
  5. what is the 2 pin connector behind the radio for?
    By A1BMW535iSport in forum 5 Series BMW
    Last Post: 11-30-2004, 09:31 AM
