Results 1 to 10 of 14
Thread: When changing the alt on an M50, how many people actually remove the fan?
    Dec 2006
    Default When changing the alt on an M50, how many people actually remove the fan?
    By a show of hands?
    I did on my 92 525ia. Needed to gain access to the belt tensioner to get belt off the alternator pulley.
    Honolulu
    Not me
    Just the airbox, boot, & MAF
    baton rouge, loserana
    i don't usually but if i am changing the belt it comes off
    Default Since it takes about 10 seconds to remove i
    almost always remove it first thing with the shroud.... Keeps me from
    A. breaking the blade or the Shroud
    B. Breaking me on the blade.
    C. makes life easier in general. More room to work, better visibility, I also like to lift the car up a little to work on it, raise it up and put it on jackstands so its at a height thats easy to bend over, in the long run anything you do to make the job easier and more comfortable makes it more likely that you'll do other jobs later on.
    Dec 2006
    i've managed to release the belt tension with the fan in place, so I am going to try to sneak it by.
    The rear battery terminals are quite difficult to get at! Any tips there?
    Thanks for the answers guys.
    disconnect the battery!!!
    Quote Originally Posted by repenttokyo View Post
    i've managed to release the belt tension with the fan in place - do you think the fan will be in the way of removing the alternator itself? I am unsure as to whether I can sneak it by.
    Dec 2006
    yes, I have done that. What I mean is, the rear terminals on the back of the alternator, the b and D cables.
    Jan 2008
    Quebec, Canada
    What about remove the bolts for the alternator and then turning the alternator to get more access to the bolts, I've never done an alternator on a M50, but I did that when I did one on a Kia Sephia, Mazda Protege, Chevy Malibu and a few others.
    BMW E34 1992 525i Touring
    Aug 2008
    Pennsylvania
    Just remove all the bolts for the alternator and then turn the alternator and you'll get the two wires.
    I've done this twice and both times I removed the fan.
  1. what would you people get? e36 or e34
    By adashio in forum 5 Series BMW
    Last Post: 05-29-2007, 09:00 AM
  2. Hi People
    By Steve Walker in forum 5 Series BMW
    Last Post: 05-21-2006, 06:05 AM
  3. Changing air filter - Which side to remove
    By Shade Tree in forum 5 Series BMW
    Last Post: 11-23-2004, 12:55 AM
  4. Replies: 5
    Last Post: 10-31-2004, 02:17 PM
  5. Replies: 7
    Last Post: 03-05-2004, 07:58 AM
