Results 1 to 10 of 13
Thread: ATF fluid change, the easy Korean way
    Default ATF fluid change, the easy Korean way
    good idea by uropal from South Korea, using a shampoo bottle pump for that
    http://www.bimmerboard.com/forums/posts/615855
    He measures exactly the volume pumped out and refills the same amount.
    Of course, ATF filter is not changed then, but a good idea for a in-between-change.
    Benneton (United Colors of)
    i've posted about using that method here several times over the past 4 years. i use a gear oil pump that (aside looking bigger than his) gets about 1 ounce a pump out. he's got his procedure wrong, though. as best as i can tell from his broken english, he warms the car up first. you have to do it when the car is stone cold, otherwise the fluid level will be wrong once the new fluid heats up. it's good for removing overfilled motor oil, evacuating brake resivoirs with a clean piece of hose, PS fluid, et cetera.
    the fluid level cannot be wrong, as he just refills what he pumps out in this procedure. You can see the measuring jar there. This procedure is of course not right if you want to measure the correct liquid level in the ATF, but it is just to show an easy ATF fluid change. Not too bad in my opinion, can be done by anybody without a pit and very easy.
    I might do it as interim partial fluid change next time, much easier than from the bottom.
    Necessity being the mother of invention and all I guess this will work. Lots of pumping with that little thing,I'll bet his wrist is sorer than a 14 year old with Dad's Playboy magagzines.
    Default The mityvac pump shown
    here is much easier , has a 8'8 liter capacity also. You can pump fluid with it as well as draw fluid out.... They have a handle like a bicycle pump, you give it about 20 strokes and then just for it to finish sucking the fluid out.
    The side of the reservoir is marked so you know how much you've taken out. Mityvac makes a number of differnet ones, one thats powered by shop air if you don't want to hand pump. A cheaper one that only evacuates doesn't allow you to pump fluid in.
    The only hassle is cleaning them, so if your going to use one to pump fluid in ,its better to have 2 one for sucking it out and one for putting it in. They also have brake bleeder adapter kits for it, to bleed your brakes with.http://www.thetoolwarehouse.net/shop/MIT-MV7201.html
    Quote Originally Posted by Bill R. View Post
    I saw someone using one of those on bobistheoilguy.com for the same purpose. I'm too cheap to buy one for this purpose, however, because all of the cars that i've ever put the hose down the dipstick on have about 3-4 quarts in the bottom, and you don't have to clean out oil motor oil bottles when you're done measuring out the evacuated amount. i have 3 lengths of hose in my toolbox to hook up to my hand pump, nasty (evacuating everything oil based), semiformal (new oil) and formal (brake fluid). that cost me about a dollar for the three, i'm too cheap to buy 2 mityvacs
    i'm going to have to disagree with your admonition that the fluid level cannot be wrong. he clearly states that he drives the car and gets it warm before he does this. he is replacing operating temperature transmission fluid with cold fluid out of a bottle. unless he's heating the fluid in the bottle up, he can't get a proportional replacement. i find that 1/2 quart of cold fluid equals about 5/8-3/4 quart hot fluid in most of the cars i play with. the idea that one can change the fluid with a hand pump is not wrong, but the idea that hot=cold level is.
    Mar 2004
    Phoenix, AZ
    Default I did it the lazy, white trash way.....
    I just rigged a glass chemistry vapor bottle with some rubber hose and attached my vacuum cleaner to it. The fluid was drawn out via vacuum and went into the bottle and not the vaccum because the tube attachment was about 1/2 inch below the opening of the bottle. I admit that I did warm it up before doing this so that it would flow faster.
    Wouldn't it make sense to measure the volume after it cools and then put back in the same amount, at the same cool temperature? You could also get some idea of the change in volume in the fluid at the hi/low temperatures.
    Does tranny fluid really change in volume at different temps?
    Any hoo, the whole contraption looked like some college kids hooka or bong. Matter of fact, I've got an idea!
    JD
    Default They are a pretty good deal when they go
    on sale. One of my friends has one at his shop and its lasted a couple of years, he's pretty bad about abusing stuff too. Uses it 3 to 4 times a week on various things.
    Quote Originally Posted by ryan roopnarine View Post
    Aug 2008
    Pennsylvania
    Its not that hard to loosen drain plug.
  1. Gearbox Oil Change - Is it easy???
    By yaofeng in forum 5 Series BMW
    Last Post: 04-05-2008, 03:43 AM
  2. Clean and easy oil change technique...
    By nuclearfusion in forum 5 Series BMW
    Last Post: 07-11-2006, 03:26 PM
  3. AutoTrans Fluid Change
    By PeterInSTL in forum 5 Series BMW
    Last Post: 09-10-2005, 04:24 PM
  4. Tranny Fluid Change
    By 525e34 in forum 5 Series BMW
    Last Post: 04-22-2005, 04:12 PM
  5. Trannie fluid change ?
    Last Post: 03-12-2004, 12:16 AM
