Results 1 to 5 of 5
Thread: Defroster question
    Sep 2007
    Michigan
    Default Defroster question
    1990 535i.
    The defrost seems to be broadcasting the warm air more generally than specifically. Is it possible that some flaps inside are not functioning or is that the normal operation? Other models I own are more direct.
    In case you have an IHKA climate control, the climate control module takes over the distribution and opening position of each flap based on many parameters such as speed and the signals from the temperature sensors inside the car. There are 2 sensors on each side of the center console and one behind the control panel. Maybe you clean the sensors, they can be very dirty.
    Sep 2007
    Michigan
    I have a temperature dial on the left, the fan speed control in the middle and a temperature control dial on the right. I have the three sliders, defrost, middle vents and feet. Is that the one you were referring to? It doesn't seem real sophisticated.
    Sep 2007
    Michigan
    Nope. That's way more than what I have. Mine looks like an older e30 unit except with an extra heat control for the passenger side. Thank goodness. That one looks like a royal pain to deal with.
  1. Rear defroster not working
    Last Post: 04-16-2007, 08:54 PM
  2. Rear Defroster Not Working
    By chiefcorey in forum 5 Series BMW
    Last Post: 11-26-2006, 06:13 PM
  3. Need Rear Defroster help
    By acidfire52 in forum 5 Series BMW
    Last Post: 10-19-2006, 09:16 AM
  4. How do u turn ON the Winshield defroster on 92 525i
    By juan525i in forum 5 Series BMW
    Last Post: 10-17-2004, 03:58 PM
  5. Removing ballpoint pen from defroster vent.
    By Dan in NZ in forum 5 Series BMW
    Last Post: 07-27-2004, 07:36 AM
