Results 1 to 4 of 4
Thread: 540 fuel pump relay location
    Jun 2006
    southaven miss.
    Default 540 fuel pump relay location
    Still chasing my 95 540/6 rough running. Went and switched fuel pumps from my other 95 540/A that runs good. Now my 540/6 will not start,just cranks. Which relay is it. In the pass side box i have one white and 3 light green ones. i figure the white is main relay,but which green one is fuelpump. thanks
    May 2006
    NH
    I thought the fuel pump relay was actually in the DME Box on the other side,no?
    1995 540i Manual build 1/95
    Jun 2006
    southaven miss.
    My box looks different. I have 4 relays in a row, 1 white, 3 light green.
    Jun 2006
    southaven miss.
    Well like a idiot i had hooked up the lines backwards. so now the car starts up obut runs really bad still. So now i have switched the fuel pump, maf and replaced the plugs, car still runs bad. Next i will change the fuel filter, have to order them since no one carries the double filters. I dont believe they could be causing my problem,but want to eliminate them.
  1. m60 Fuel Pump Relay Location
    By artguy in forum 5 Series BMW
    Last Post: 12-05-2007, 09:56 PM
  2. Replies: 8
    Last Post: 07-02-2006, 07:58 PM
  3. M50 coils, main relay or fuel pump relay?
    Last Post: 05-31-2006, 07:48 PM
  4. fuel pump relay location
    By moots in forum 5 Series BMW
    Last Post: 07-29-2004, 06:01 AM
  5. fuel pump relay location ?
    By silver-e34 in forum 5 Series BMW
    Last Post: 03-29-2004, 09:30 AM
