dear friends this afternoon when I stop the car I realized that there is a sound under car. it was a tickling sound. I pressed to clutch pedal and it was gone. I understand that it is bearing. Then my father moved the car and I walk close to the car and when moving there is no such sound only when gearsn neutral position. suddenly I realized that engine heat was so high and it was close to red region. I waited nothing happened. it was standing still right close to red region. I opened heat inside cabin the engine temp decreased. when I turn of heat dials off, it clibed up again. Sound was still there. then when it was neutral I tried to rev the engine up aroun 4000 rpm and gauge showed that heat decreased to normal. then it stayed little bit above the normal marker. when I press clutch pedal sound is dissapearing and temperature decreases little bit and reaches to the normal marker when I remove my foot it moves little up and at the same time sound is persistent. what do you thing? fan is working water is enough inside radiator.performance and on road condition of my car is very nice. but differently when that sound is coming car is vibratin during idling.
can only a simple bearing cause this problem? I replaced water pump 20000 km before. now my car is showing 130000 km on its odometer and it is in very good condition. clutch has never been changed before. but there is no problem in acceleration shifting or during engine braking. it is 94 make e34 520i m50 .
this morning I realized that there is no noise and no vibration. may be when car is heated, this is causing enlargement on some parts and this is causing problems?
