Thread: cooling fan removal tool DIY -pics
    Default cooling fan removal tool DIY -pics
    longest one I have ever seen
    but for sure works
    http://www.bimmerboard.com/forums/posts/601896
    Sometimes the leverage is necessary. My first time removing my fan, I made my own tool long enough to jam it against the frame rail on the driver's side of the engine bay and use a big (and I mean BIG) wrench to get the fan loose. Sure wanted to use the wrench on the mechanic who tightened the piss out of the fan some 300 miles earlier. After that first time, I've been able to loosen the fan with a light slap on the wrench because I don't tighten it with a pipe wrench. Word to the wise: fans don't come loose on these cars, so don't tighten them other than spinning the fan up as you are threading it on. One good spin and it tightens up perfectly. Just my $.02
    That is right, I even do not tighten the fan at all, I just spin the fan up when threading it on and the rest of tightening is done with the next engine start.
    Perfect fit and easy to remove then.
    Aug 2008
    Pennsylvania
    I use tap the wrench with my fist and the fan comes loose. The first time I removed my old fan clutch I had to give the wrench a few good wacks with the hammer.
    Round Lake/Volo Illinois
    I did it today with a wrench. Grabbing a fist full of wrench didn't budge it, but a light tap with a dead blow and she came right loose.
    Josh
    Jan 2007
    Dayton Ohio
    Default Rubber mallet
    I used a rubber mallet and smacked it once.
    but for sure works
  1. Online tool rental? - cooling system issue
    By Milkboot in forum 5 Series BMW
    Last Post: 08-20-2007, 10:46 PM
  2. where can I get a wheel cap removal tool?
    Last Post: 05-21-2006, 11:52 PM
  3. Cooling Fan Removal
    By MantecaBMW in forum 5 Series BMW
    Last Post: 01-11-2005, 06:07 PM
  4. Cooling Fan Removal:E34 1995 525i M52 Engine
    By Eric Fraser in forum 5 Series BMW
    Last Post: 09-05-2004, 05:29 PM
  5. Where to get a tie-rod removal tool?
    By MO525 in forum 5 Series BMW
    Last Post: 03-30-2004, 05:00 PM
