hi, welcome try this, it might help http://www.bmwe34.net/Wiki/tiki-inde...ard+capacitors
Hi All
1. I have a 1992 E34 525i Automatic. When I push the control check display, nothing shows up. Is this normal?
2. After a few seconds of starting the car, the service level indicator goes off as well as the transmission selector display. Is this normal?
If not, please could somebody help in determining what the problem could possibly be.
Bob
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
Thank you. Will give it a try
Hi whiskychaser
1. I was selecting the button on the speedo cluster. I am new to BMW's. Should that be a problem?
2. Selector Display goes out a few seconds after the service indicator and both digits go out.
Press the button on the end of the indicator stalk to show check control display. Once its on, press it again to get different indications eg time, temp, fuel consumption. You cancel the display by pressing the cluster button
If the gearbox works ok in all modes and the check control doesnt come on (or goes off like the gear indicator) its odds on the display is at fault as has been suggested.
HTH
