Results 1 to 2 of 2
Thread: Component Abbreviations and the usage at BMW
    Default Component Abbreviations and the usage at BMW
    Do you know what DZM, ACC or EDC means? What does the car maker say if they want to use a AHPS?
    The secret is that many OEMs use different abbreviations and shortcuts do describe the components used in their cars.
    Most time also within the component these shortcuts can be trademarked or are copy-protected.
    The effect is that with increased amounth of components and different branded names for actually similar components at the vehicle maker, as well additional even the local company internal rules for used language standards increase and multiply the possible abbreviatens used siginificantly.
    This sometimes it is getting very confusing when suppliers and OEMs talk about their used components.
    And it is discussed in many different news-groups.
    Abbreviations@BMW
    One of the most popular OEM with very complicated and in the first sense unclear abbreviations is BMW.
    The problem is that they are using German as the base language to create their abbreviation.
    This makes the Tire Pressure Control to “RDC-Reifen Druck Control” or the climate control panel to “KBT Klimabedienteil”.
    Glossary of BMW Terms and Abbreviations
    A - processed vehicle speed signal
    A - “out” (Aus)
    AB - Airbag
    ABL - Brake system warning Lamp (2 color)
    ABS - Anti-lock Braking System—-Antiblockiersystem
    AC - Air Conditioning (from ETK)
    ACC - Active Cruise Control
    ACS - Active Comfort Seats
    ADB(X) - Automatic Differential Braking
    ADS - engine intake air control
    ADV - windshield wiper pressure control—-Anpressdruckverstellung
    AEGS - Automatic Electronic Gearbox Control (also EGS)
    AFM - Air Flow Meter—-Luftmengenmesser
    AGD - suction silencer (from ETK)—-Ansauggeraeuschdaempfer
    AGR - emission reduction
    AGS - Adaptive transmission control—-adaptive Getriebesteuerung
    AG - Automatic Gearbox (transmission)—-automatisches Getriebe
    AHK - Active rear-axle Kinematics
    AHK - trailer hitch (from ETK)—-Anhaengerkupplung
    AHM - trailer Module (not for US models)
    AHPS - Advanced HPS
    AIC - Automatic Interval Control (rain sensor)
    AKF - activated carbon canister (from ETK)
    AKS - Active head restraint
    AKS - pressure regulating device (from ETK)
    ALC - Automatic Light Control
    ALR - Automatic Lamp Range Adjustment
    AMM - Air Mass Meter—-Luftmassenmesser
    AMP - radio system AMPlifier
    ARI - car radio information system (from ETK)
    ARS - Active Roll Stabilization
    ASC - All Season traction
    ASC-EZA - ASC w/ engine timing and injection intervention
    ASC+T - ASC+ Traction control
    ASK - Audio System controller (Kontroller)
    ASR - self starter block relay (from ETK)
    AST - Automatic Slip control (marketing term)
    AT - remanufactured part (from ETK)
    AT - Antenna (from ETK)
    ATF - Automatic Transmission Fluid (from ETK)
    ATL - exhaust gas turbo charger (from ETK)—-Abgasturbolader
    AUC - Automatic air recirculation
    AUT - AUTomatic transmission (from ETK)
    AVT - Antenna amplifier Tuner
    AZD - tightening torque specifications (in TIS)
    A/D – Analog/Digital
    B - Benzene (gasoline)—-Benzin
    BAT - BATtery (from ETK)
    BC - Board Computer
    BC1 - Body Controller 1
    BL - Brake Light (from ETK)—-Bremslicht
    BLS - Brake Light Switch—-Bremslichtschalter
    Bluetooth - A wireless interconnection technology that automatically recognizes and communicates with components (such as cell phones, headsets and computing devices) when brought into close proximity (generally 30 feet or less).
    BMBT - Board Monitor
    BS - Block diagram
    BST - Battery Safety Terminal
    BVA - Brake pad wear indicator (from ETK)—-Bremsbelagverschleissanzeiger
    BZM - center console control center
    BZMF - center console control center, rear
    CAN – Controller Area Network (Multiple ECU Controller)
    CAN-Bus - Controller Area Network (bus)
    CANH-Bus - CAN bus, High
    CANL-Bus - CAN bus, Low
    CANP - fuel tank ventilation valve
    CAS - Car Access System
    CBC - Corner Braking Control
    CBS - Condition Based Service
    CCM - Check Control Module
    CD - Control Display
    CDC - Compact Disk Changer
    CDS - CD player (from ETK)
    CEL - CELsius (from ETK)
    CIM - Chassis Integration Module
    CO - Carbon monOxide (from ETK)
    COMBI – Electronic Instrument Cluster
    CON - CONtroller
    CU - Copper (from ETK)—-Kupfer
    CVM - Convertible top Module
    CVT - Constantly Variable Transmission
    CW - drag coefficient (from ETK)—-Luftwiderstandsbeiwert
    CWP - Cold Weather Package
    D1 - Xenon light/ gas discharge (from ETK)
    D-Bus - Diagnosis bus (same as TXD)
    DBC - Dynamic Brake Control
    DBS - Dynamic Braking System
    DCS - Dealer Communication System
    DE – Diagnostic Unit—-Diagnoseeinheit
    DD - Dynamic motor Drive
    DDE - Digital Diesel Electronics
    DIN - German industrial standards
    DIS - Diagnosis and Information System
    DISA - Differential air intake control
    DIVA - continuously variable length intake runners
    DK - throttle housing/valve—-Drosselklappe
    DKB - throttle w/ brake intervention
    DKE – Throttle Increase
    DKI - throttle position
    DKR - throttle reduction
    DKT - throttle position signal
    DKV - preset throttle position value
    DME - Digital Motor Electronics
    DM-TL - Diagnostic Module Tank Leakage
    DOHC - Double Over Head Camshafts (from ETK)—-doppelte obenliegende Nockenwelle
    DS - gasket set (from ETK)—-Dichtungssatz
    DSC - Dynamic Stability Control
    DSP - Digital Sound Processing
    DTC - Diagnostic Trouble Code (SAE)
    DTC - Dynamic Traction Control
    DWA - theft deterrent system—-Diebstahlwarnanlage
    DWS - tire pressure Warning System—-Druckwarnsystem
    DZM - revolution counter (from ETK)—-Drehzahlmesser
    E - “in” (Ein)
    EBA - EinBau Anleitung (translated Installation Instructions). This is a CD-ROM with installation instructions for various options and upgrades.
    EBV - Electronic Brake force proportioning—-elektronisches Bremsventil
    ECE - European market version (from ETK)
    ECM - Engine Control Module (SAE term)
    ECU - Electronic Control Unit
    EDC - Electronic Damper Control (from ETK)
    EDR - Electronic throttle control—-elektronische Drehzahlregelung
    E-KAT - Electrically heated catalytic converter—-beheizter KAT
    EZA - see ASC-EZA
    ECO - Controller for I-Drive system
    EDC - Electronic Dampening Control—-elektronische Daempferkontrolle
    EDC-K - Electronic Dampening Control - Continuous
    EDK - Electronic throttle valve—-elektronische Drosselklappe
    EDS - pressure regulator—-Druckspeicher
    EFH - Electric window lifter (from ETK)—-elektrische Fensterheber
    EGS - Electronic transmission control—-elektronische Getriebesteuerung
    EH - Electronic-Hydraulic
    EHC - Electronic Height Control
    EKM - Electronic body Module—-elektronisches Karosserie Modul
    EKP - Electric fuel Pump—-elektrische Kraftstoffpumpe
    ELV - Electronic steering lock—-elektronische Lenkradverriegelung
    EM - Electro-Mechanical—-elektro-mechanisch
    EMF - Electro-Mechanical parking brake—-elektro-mechanische Fussbremse
    EML - Electronic Motor Load regulation—-Elektronische Motorlastregelung
    EMV - Electro-Magnetic sensitivity (from ETK)—elektromagnetische Vertraeglichkeit
    EO - component location—-Einbauort
    EPC - Electronic Parts Catalog (also ETK)
    EPROM - Erasable/ Programmable chip Memory (from ETK)
    ETK - Electronic parts catalog (also EPC)—-Ersatzteilkatalog
    ETM - Electrical Troubleshooting Manual
    ESS - Electronic anti-theft device—-Elektronisches Sicherheits System
    EV - injection Valve—-Einspritzventil
    EWS - Electronic drive-away protection—-Elektronische Wegfahrsperre
    FB - Function description—-Funktionsbeschreibung
    FBC - Fading Brake Control
    FBD - remote control services—-Fernbedienung
    FBZV - radio frequency locking system
    FGR – Vehicle Speed Control (Cruise Control)—-Fahrzeuggesxchwindi
    FH - window lifter—-Fensterheber
    FHK - rear Heater/ air conditioner
    FLC - automatic Light Control
    FRU - Flat Rate Unit
    FS – Crash Sensor
    FZV - central lock receiver
    GAL - speed dependent sound volume—-geschwindigkeitsabhaengige Lautstaerkeregelung
    GM - General Module—-Grundmodul
    GMR - yaw moment control—-Giermomentregelung
    GPS - Global Positioning System
    GRII - cruise control—-Geschwindigkeitsregelung II (Tempomat)
    GRS - rotation Rate Sensor
    GS – Belt Tensioner
    GWK - torque converter lock-up control
    H - “rear” (Hinten)
    H2 - Xenon headlights
    HA - rear Axle (from ETK)—-Hinterachse
    HC – Hydro Carbon
    HD - Heavy Duty (from ETK)
    HDC - Hill Decent Control
    HFM - Hot Film air mass Meter—-Heissfilmluftmengenmesser
    HG - manual Gearbox (transmission)—-Handschaltgetriebe
    HKL - Hydraulic trunk lid Lift—-hydraulischer Kofferraumdeckellifter
    HLM – Hot Wire Air Mass Meter—-Heissdrahtluftmengenmesser
    HPS - Head Protection System
    HR - Heater control (from ETK)—-Heizungsregelung
    HVA - Hydraulic Valve Adjuster (from ETK)
    Hz – Hertz (Cycle)
    I-Bus - Information bus
    IB - Interior lighting control signal
    IHKA - automatic Heating and A/C
    IHKAF - IHKA w/ micro filter
    IHKR - regulated Heating and A/C—-Integrierte Heizungs-Klimaregler
    IHKRF - IHKR w/ micro filter
    IHKS - standard Heating and A/C—-Integrierte Heizungs-Klimasteuerung
    IHPD - Internal High Pressure Deformation
    IHR - Integrated Heater control (from ETK)—-integrierte Heizungsregelung
    IKE - Instrument cluster Electronics
    ILH - Interior Lighting, rear—-Innenlicht, hinten
    ILV - Interior Lighting, front—-Innenlicht, vorne
    IMS - Instant Mobility System (from ETK)
    IR – Infrared
    IRS – Infrared Locking System
    ISC – Idle Speed Control
    ISIS - Intelligent Safety Integration System
    ISN - Individual Serial Number
    ISOFIX - standardized mounts for child restraints
    ITS - head airbag assembly/ Inflatable Tubular Structure
    IVM - Integrated power supply Module—-Integriertes Versorgungsmodul
    K-Bus - body bus (Karosserie)
    KAT - catalytic converter—-katalysator
    KATON - converter creating (signal)
    KD - Kick-Down
    KDS - Komputer Service Desk (Translated Computer) A CD-ROM that inlcudes the defect codes and flat rate labor units BMW allows for the warranty repair of defects.
    KHI - interface for headphones—-Kopfhoererinterface
    KL - terminal designation—-Klemme
    KL15 - run bus (ignition switch run position)—-Klemme 15
    KL30 - battery bus (hot at all times)—-Klemme 30 (Dauerplus)
    KL31 - ground bus (chassis ground)—-Klemme 31 (Masse)
    KL50 - start bus (ignition start position)—-Klemme 50
    KLR - accessory bus
    KO - compressor “on” signal
    KOMBI - instrument cluster—-Kombiinstrument (Tacho-Drehzahlmesser, usw.)
    KOREL - compressor relay signal
    KR – Contact Ring
    KSK - Knock Sensor—-Klopfsensor
    KVA - fuel consumption signal/value
    KW - crankshaft—-Kurbelwelle
    KW - KiloWatt (from ETK)
    LCM - Lamp Check Module
    LDP - Leak Diagnosis Pump
    LEV - Low Emissions Vehicle
    LEW - Lateral acceleration sensor
    LHD - Left-Hand Drive (from ETK)—-Linkslenker
    LKM - Lamp control Module—-Lampenkontrollmodul
    LL - closed throttle—-Leerlauf
    LM - Light Module—-Lichtmodul
    LMM - air flow meter/sensor—-Luftmengenmesser/Luftmassenmesser
    LMR - Light alloy wheel—-Leichtmetallrad
    LRA - vertical headlight aiming—-Leuchtweitenregelung
    LSM - steering column memory—-Lenksauelenmemory
    LSZ - Lamp Switching center
    LVA - air supply system (for EHC system)—-Luftversorungsaggregat
    LWR - vertical headlight aim control—-Leuchtweitenregelung
    LWS-5 - steering angle sensor—-Lenkwinkersensor
    M-Bus - IHKA/IHKR stepper motor bus
    MAL - center armrest—-Mittelarmlehne
    MBC - Maximum Brake Control
    MDK - Motorized throttle valve/system
    MFL - Multi-Function steering wheel—-Multifunktionslenkrad
    MFC - Multi-Function Controller
    MFU - Multi-Function Clock—-Multifunktionsuhr
    MID - Multi-Information Display
    MIL - Malfunction Indicator Lamp (SAE), “check engine” Lamp
    MIR - Multi-Information Radio
    MMC - Multi-Media Changer
    MoDiC - Mobile Diagnostic Computer
    MOST-Bus - Media Oriented System Transport bus
    MRS - Multiple Restraint System—-Mehrfach-Rueckhalte-System
    MSR - engine drag torque Regulation—-Motorschleppmomentregelung
    MV - Magnetic Valve (solenoid Valve)—-Magnetventil
    n-ab - rotational speed, transmission (rpm)—-Drehzahl der Getriebeabtriebswelle
    n-mot - rotational speed, engine (rpm)—-Motordrehzahl
    NAVI - Navigation module
    NG - New Generation (as in N73 engine)
    NG - tilt sensor—-Neigungssensor
    NOX - Nitrogen Oxides/ exhaust gas recirculation (from ETK)
    NSD - rear muffler (from ETK)—-Nachschalldaempfer
    NSL - rear fog Lamp (from ETK)—-Nebelschlussleuchte
    NSW - fog lamp (from ETK)—-Nebellampe
    NTC - Negative Temperature Coefficient
    NW - camshaft (from ETK)—-Nockenwelle
    OBC - On-Board Computer
    OBD - On-Board Diagnosis (SAE)
    P/N – Park/Neutral position
    P-Bus - Periphery bus
    PB - Pin assignments—-Pinbelegung
    PBS - Parts Bulletin System (in TIS)
    PDC - Park Distance Control
    PGS - Passive Go System
    PM - Power Module
    PP – Impact Pad
    PTC - Positive Temperature Coefficient
    RLS - Rain-Light Sensor—-regen-Licht-Sensor
    PWG - Pedal position sensor/ potentiometer—-Pedalwertgeber
    RA - Repair instructions (in TIS)
    RAM – Random Access Memory
    RAL - Aluminum wheels (from ETK)
    RAL - standard color (from ETK)—-Reichsausschuss-fuer-Lieferbedingungen
    RDC - tire pressure Control—-Reifendruckkontrolle
    RDS - Radio Data-broadcast System
    RDW - tire pressure Warning—-Reifendruckwarner
    RHD - Right-Hand Drive (from ETK)—-Rechtslenkung
    RM - Relay Module—-Relaismodul
    ROZ - Research Octane rating/ fuel grade (from ETK)
    RPA - tire puncture warning (from ETK)
    RPS - Rollover Protection System
    RS - Repair kit (from ETK)
    RSW - back-up lamp (from ETK)—-Rueckfahrscheinwerfer
    RXD - wake-up Diagnosis line
    RZV - direct stationary ignition
    SASL - Satellite, A-pillar left
    SASR - Satellite, A-pillar right
    SAV - Sport ACTIVITY Vehicle
    SB - fuse assignments
    SBE - Seat occupancy detector/sensor—-Sitzbelegungssensor
    SBFH - Seat module, passenger-side rear
    SBSL - Satellite, B-pillar left
    SBSR - Satellite, B-pillar right
    SBT - SI techniques/ tech reference information (in TIS)
    SCA - Soft Close Automatic/Actuator
    SD - sliding roof (from ETK)
    SD - silencer/ muffler (from ETK)—-Schalldaempfer
    SE - Special Equipment (from ETK)
    SES - voice recognition System
    SFAH - Seat module, driver’s side rear
    SFZ - Satellite, vehicle center
    SG - control unit
    SGS - Seat integrated belt System
    SHD - sliding/ lifting roof (from ETK)—-Schiebe-Hubdach
    SHD - Sunroof module (also SHDM)
    SI - Service Information (in TIS)
    SIA - Service Interval system (ver. I, II, III, IV, etc.)
    SII - Service Interval Indicator
    SIL - SILicon (from ETK)
    SIM - Safety Information Module
    SINE - Siren/tilt sensor
    SKD - Steel sliding roof (from ETK)—-Stahlkurbeldach
    SKHD - Steel sliding/ lifting roof (from ETK)
    SM - Seat Module
    SM/SPM - Seat/Mirror Memory
    SMBF - Seat Module, passenger side
    SMFA - Seat Module, driver’s side
    SMG - Sequential Manual Gearbox—-Sequentielles-Manuelles -Getriebe
    SP - Schematic
    SRA - headlight/fog light cleaning—-Scheinwerferreinigungsanlage
    SRS - Supplementary Restraint System—Sitz-Rueckhaltsystem
    SSD - Steel sliding roof (from ETK)—-Stahlschiebedach
    SSH - Seat Satellite, rear seat
    ST - connector views
    Steptronic - transmission shift control
    STVL - Satellite, left front door—Satellit, Tuer vorne links
    STVR - Satellite, right front door—Satellit, Tuer vorne rechts
    SVS - Speech processing System—-Sprachverarbeitungssystem
    SWR - headlamp cleaning system (from ETK)—-Scheinwerferreinigungsanlage
    SWZ - Special tool listings (in TIS)—-Spezialwerkzeug
    SZL - Switch center, steering column
    SZM - central switch center Module
    TAGE - door handle Electronics
    TCM - Transmission Control Module
    TD - engine speed signal (ignition pulse)
    TD - Technical Data (in TIS)
    TDD - Technical Documentation Disk. Made availble to consumers and dealers by force of the DOT/EPA regulations for servicing the electrical and mechanical components of the emissions replated systems on the cars that are not on the ETM.
    TE - fuel evaporation control—-Tankentlueftung
    TEL - TELephone control unit
    TEV - evaporative purge control—-Tankentlueftungsventil
    THZ - Tandem master cylinder (from ETK)—-Tandemhauptzylinder
    ti - Injector “on” Time (duration)—-transmittierende Injektion (Einspritzung)
    TIS - Technical Information System
    TL - part throttle / load signal—-Teillast
    TLEV - Transitional Low Emission Vehicle
    TMBFT - door Module, passenger side
    TMBFTH - door Module, passenger side rear
    TMFAT - door Module, driver’s side
    TMFATH - door Module, driver’s side rear
    TP - Tandem Pump (from ETK)
    TPS - Throttle Position Switch/Sensor
    TR - engine speed signal (rpm)
    TR - TRansistor (from ETK)
    TRG - fuel level sensor (from ETK)—-Treibstoffstandgeber
    TRI - Technical Reference Information (also SBT)
    TRS - battery isolation Switch
    TSD - Torsional vibration dampener (from ETK)
    TSB - Technical Service Bulletin
    TSH - door lock Heating—-Tuerschlossheizung
    TSZI - Transistorized coil Ignition system (from ETK)—-Transistorspulenzuendung
    TU - Technical Update (as in M50tu)
    TXD - Transmitting Diagnosis line
    U-batt - Battery voltage—-Batteriespannung
    U-vers - supply voltage—-Spannungsversorgung
    UERSS - rollover bar (from ETK)—-Ueberrollschutz
    URS - rollover protection System
    USIS - Ultrasonic passenger compartment Sensor
    V - “front” (Vorn)
    V - vehicle road speed—-Geschwindigkeit
    VA - front Axle (from ETK)—-Vorderachse
    VAT - front axle support (from ETK)—-Vorderachstraeger
    VANOS - Variable camshaft timing—-Variable Nockenwellensteuerung
    VEP - distributor-type injection Pump (from ETK)—-Verteilereinspritzpumpe
    VID - VIDeo module
    VL - full load (wide open throttle)—-Volllast
    VSD - front muffler (from ETK)—-Vorschalldaempfer
    VVT – Valve tronic
    WBG - hazard warning switch (from ETK)—-Warnblinkanlage
    WIM - Wiper control Module
    WK - torque converter lock-up clutch—-Wandlerueberbrueckungskupplung
    WSS – Wind Shield (from ETK)—-Windschutzscheibe
    WT – Valve tronic control unit
    Z - “central” (Zentrum)
    ZAB - ignition fade-out (reduction)
    ZAE - central Airbag Electronics
    ZAS - ignition starter switch (from ETK)—-Zuend-Anlass-Schalter
    ZGM - central Gateway Module
    ZK - cylinder head (from ETK)—-Zylinderkopf
    ZKE - central body Electronics—-Zentrale Karosserie Elektronik
    ZKH - cylinder head cover (from ETK)—-Zylinderkopfhaube
    ZMS - dual-Mass flywheel (from ETK)—-Zweimassenschwungrad
    ZV - central locking system—-Zentralverriegelung
    ZS - central lock (from ETK)—-Zentralschluessel
    ZSD - center muffler (from ETK)—-Zentral(mittel)schalldaempfer
    ZV - central locking system (from ETK)
    ZVM - central locking Module—-Zentralverriegelungsmodul
    ZWD - idle control valve
    Wow. That's a lot of info.
  1. abbreviations used internally in BMW
    Last Post: 05-25-2006, 12:12 AM
  2. Sword: Other component failing?
    By PABLO in forum 5 Series BMW
    Last Post: 12-30-2004, 09:40 PM
