Results 1 to 2 of 2
Thread: #10 fuse blowing
    Sedro-Woolley, WA USA
    Default #10 fuse blowing
    My warning chime went off, and I got a 1 low beam warning. I checked the headlights and the L low beam was out. Opened the fuse box, and sure enough, the #10 fuse was blown. I replaced it, and it blew within 20 seconds. VOM across the #10 slot showed 9.48v with the light switch off, and 13.4 on.
    Replaced the fuse again, and it blew again....so,
    being that I cant locate my Bentley manual, Im stumped-
    Could it be a sticky/bad relay, or more likely bad wiring to the L low, or?
    If its relay, wich one is it?
    Thanks in advance for any help!!
    Regards-
    Art.
    Check the headlight bulb... disconnect it and see if it still draw too much electricity. Use Amp DC to measure at the fuse terminals.
  1. Fuse #5 keeps blowing...
    By Hornswoggler in forum 5 Series BMW
    Last Post: 06-06-2016, 05:37 PM
  2. Fuse 4 keeps blowing
    By E34-520iSE in forum 5 Series BMW
    Last Post: 06-29-2009, 05:15 PM
  3. Fog light fuse keeps blowing
    By Calico_NC in forum 5 Series BMW
    Last Post: 09-24-2006, 02:01 AM
  4. Fuse #4 Keeps Blowing
    By deadpheasant in forum 5 Series BMW
    Last Post: 09-03-2006, 10:19 AM
  5. Replies: 11
    Last Post: 06-30-2005, 09:30 PM
