Thread: manual transmission fill
    Jul 2004
    New Haven, CT
    Default manual transmission fill
    last fall my 1995 5 speed had new amsoil synthetic installed. Now that cold weather is here it is extremely hard to shift when cold, warm is fine. I checked the manual today and BMW calls for ATF in my transmission, did I screw up?
    Thanks in advance,
    John
    Nov 2006
    Mid-Atlantic, USA
    Not if you used Amsoil ATF !!
    that would do it huh?
    Quote Originally Posted by BMWCCA1 View Post
    East Brunswick, New Jersey
    Any ATF will do.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Connecticut
    I tried several synth ATFs in my 535i but the shifting was notchy compared to the regular stuff. It shifts smoothly with the cheap Napa ATF so I give it what it likes & save $$$.
    90 535im
    02 R1100S, 87 R100S
    76 R90/S,73 R75/5
    Alfa Romeos- 65 Giulia Spider Veloce
    & 66 Duetto 1600 Spider
    Albuquerque, NM
    Quote Originally Posted by John B. View Post
    Ditto. I've tried just about everything there is. I started out with full synthetic ATF which felt like it was too slippery for the syncro's to function properly. Then I tried 70W80 GL-4 which worked ok in the summer but was too notchy when cold. After surfing the web, I tried Swepco 201 that is poplar with the Porsche gearboxes. It was very smooth for 3 seasons but took several miles on cold mornings so get smooth. Then I tried Pennzoil "Syncro-Mesh" which was the smoothest of all regardless of temps but one of the posters on the old Roadfly e28 forum e-mailed Pennzoil's tech department and they said it was specifically formulated for certain Mitsubisi manuals that had syncro issues but was not the right stuff for the Getrag trannies. I finally went with Redline MTL and it works the best of any. Most if not all current ATF's are some ratio of synthetic blends so I decided to stay away from them. If you could find the old Dexron 2 ATF, that would be worth trying.
    gale
  1. Replies: 7
    Last Post: 06-24-2008, 08:23 PM
  2. Manual Transmission Rebuild
    By Aaron Bakos in forum 5 Series BMW
    Last Post: 07-12-2007, 09:49 PM
  3. The best oil for a manual transmission?
    By J.DeFeo in forum 5 Series BMW
    Last Post: 08-14-2006, 04:35 AM
  4. manual transmission getting hot?
    By mikemaster in forum 5 Series BMW
    Last Post: 07-14-2004, 10:33 PM
  5. Manual Transmission Needed 92 535
    By talltorontoguy in forum 5 Series BMW
    Last Post: 03-17-2004, 11:10 AM
