Thread: Gauge cluster capacitors
    Aug 2008
    Pennsylvania
    Default Gauge cluster capacitors
    I need to replace the capacitors in my 95' 525i. According to BMWe34.net, there are two types of clusters. However, it did not list the types of capacitors needed for the 92' and after clusters. Anyone know which ones I need?
    Nov 2005
    Hate to break it to you, but I think you'll have to find out when you open it. Not ideal, but not much of any other way about it.
    That's how I had to do it. There are a lot of those in there, and as for me, I wound up replacing just one that had leaked pretty bad. Otherwise it's working just fine, and not perfect.
    I don't think there are plans of the circuit board going around.
    I could be wrong of course.
    Aug 2008
    Pennsylvania
    There are a total of 6 capacitors.
    as long as they fir it does not matter so much
    http://www.bimmerboard.com/forums/posts/556771/
    I have replaced them ALL with 35 Volt ones.
    You just have to pay attention to the diameter, otherwise they do not fit, max. thickness/diameter of 10 mm is possible and NOT higher than 16 mm.
    The distance between the "feet/legs" of the capacitor should be 5 mm.
    So the dimensions are the most important, the rest does not matter much.
    Aug 2008
    Pennsylvania
    Thanks for the link. So from the link I need 3 220uf and 2 22uf.
    Nov 2005
    I got a 92/7 build date, and the one I had to replace was a 1000µF 12V. The list is for 1988 7 series. My cluster has a blue back.
  1. Capacitors in a 92 e34 Cluster (blue cluster)
    By BMWDriver in forum 5 Series BMW
    Last Post: 07-20-2009, 08:30 PM
  2. Gauge Cluster Q
    Last Post: 11-03-2007, 07:48 PM
  3. Dash cluster capacitors need help part no.
    By takumidrift30 in forum 5 Series BMW
    Last Post: 09-13-2006, 05:03 PM
  4. Feeler: E34 Gauge Cluster
    By JAlfredPrufrock in forum 5 Series BMW
    Last Post: 04-03-2005, 03:52 PM
  5. Capacitors in a '95 Cluster...dif than E34.net
    By Aaron Bakos in forum 5 Series BMW
    Last Post: 01-11-2005, 08:48 PM
