Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Broken fuel tank strap
    Jan 2007
    Dayton Ohio
    Shogun The valve that is missing is a hose is the fuel pressure valve. What happens when the hose is missing on this valve. Does it make the vehicle hard to start? Also wouldn't it cause the engine to run and idle poorly?
    If the FPR is disconnected you will have two problems:
    1) The FPR will always be closed thereby providing maximum pressure to the injectors at all times. It should open under vacuum...such as at idle.
    2) You will have a vacuum leak because the vacuum hose is unhooked from the FPR. This could explain the poor engine performance.
  1. Replies: 9
    Last Post: 02-14-2008, 01:36 AM
  2. stuck gas tank strap bolts
    By colo525i in forum 5 Series BMW
    Last Post: 11-26-2006, 10:37 PM
  3. Gas tank strap
    By qball in forum 5 Series BMW
    Last Post: 11-01-2005, 10:28 AM
  4. Fuel tank strap snapped...p/n?
    By DanH in forum 5 Series BMW
    Last Post: 07-13-2004, 03:21 PM
  5. fuel strap replacement DIY help
    By InfernoM3 in forum 5 Series BMW
    Last Post: 06-08-2004, 09:18 PM
