Results 1 to 4 of 4
Thread: 1995 525i won't start
    Jan 2008
    Default 1995 525i won't start
    My 1995 525i ran like a charm yesterday. This morning, It would turn over, but would not start. I pulled and checked all the plugs - Good. Checked for hot spark - good. Checked the fuel pump fuse and relay - good. checked for voltage at the fuel pump - 12.3v good. Then, I pulled the fuel pump and put an independent 12 volts to the pump terminals - the pump ran. So...I'm getting a hot spark and voltage to the fuel pump which ran on the bench. Does anyone have any suggestions? I'm stuck.
    Jan 2008
    I've had an afterthought...Just because the pump runs when 12v is applied on the bench does not necessarily mean that it will put out sufficient pressure in the tank, correct? It could be spinning but not pumping, right?
    Oldham, England
    Quote Originally Posted by pcross View Post
    It may run ok on a bench but the fuel system runs at about 50 psi so the pump may be a bit lazy. Best way to check is with a pressure gauge. Did you try jumpering the relay and checking that fuel is making it to the rail?
    Jan 2008
    Yes. I jumpered the relay. Fuel was dribbling from the rail. Bad fuel pump. Ordered another today. Thanks much, Whiskeychaser.
  1. E34 1995 525i Auto Won't Start
    By Don_B in forum 5 Series BMW
    Last Post: 01-12-2009, 05:23 PM
  2. 1995 E34 525i Still will not start
    By pcross in forum 5 Series BMW
    Last Post: 12-02-2008, 04:37 PM
  3. 1995 525i tourer, wont start - Please help!!
    By royal in forum 5 Series BMW
    Last Post: 11-19-2006, 03:23 PM
  4. 1995 M50 becoming harder to start
    By Chris I. in forum 5 Series BMW
    Last Post: 04-04-2005, 01:18 PM
  5. 1995 525i won't start
    By K_Po_Uno in forum 5 Series BMW
    Last Post: 01-07-2005, 11:35 PM
