Results 31 to 38 of 38
Thread: charging woes part III "The Return"
    Aug 2008
    Default charging woes part III "The Return"
    ok we've been through this before.... how complicated can a charging system be?
    (depends on the idiot testing it, i guess )
    3rd alternator exhibits the same symptoms as the previous 2... basically...
    -14.3v at idle nothing on
    -12.0v at idle everything on
    supplier insists all 3 were good.
    Battery loses charge overnight (last night 12.50 to 12.39... maybe not so bad? I will try again tonight...)
    Draw test = 20mA very consistently now.
    Everything stock except stereo head unit which I am very confident is not suspect.
    Anything electrical works 100% except a fog light indicator in the clusterboard, the passenger in-seat heat, and the fuel guage is whacked.
    Battery passed a load test at a trusted garage last wednesday. New december 2007. Moll 91, i guess that's small but it's stock size at least.
    I'm testing with two cheap multimeters but they compare well so I am confident with my results.
    if you are bored with life you can read some long backgrounds (ptI ptII) and a funny noob hijack of an otherwise useful shogun thread that is somewhat related,
    but I think that's all the important stuff.
    it's gotsta be the battery? no? how 4sure is a load test?
    aaaaargh i'm going !
    *-AE was right all along i hope? since this post i had it tested and it passed... but... (?)
    Quote Originally Posted by attack eagle View Post
    I'd venture to guess you have a bad cell or two in the battery so you have voltage but not the amperage to back it up, and it is dragging your alternator output down by being a constant load.
  1. charging woes part IV 'The Wrath of Tim'
    Last Post: 11-12-2008, 02:15 PM
  2. charging woes part V "The Search for Spark"
    Last Post: 11-12-2008, 02:11 PM
  3. Replies: 5
    Last Post: 01-09-2006, 01:48 PM
  4. "ended" Part numbers in the ETK
    By infinity5 in forum 5 Series BMW
    Last Post: 03-05-2005, 11:33 PM
