Results 1 to 4 of 4
Thread: Securing rear window switch
    Jan 2005
    Williamsburg, VA
    Default Securing rear window switch
    I'm reassembling the left-rear door panel after replacing a faulty lock actuator. I've put the power window switch back in place, but I don't understand what holds it in place. There doesn't appear to be anything that "snaps" into place.
    I can put the switch in the opening and attach the wiring harness behind it... but it just falls back out of the opening into the cabin.
    Anyone remember how the switch stays put?
    Norman
    '89 535i, 225000 miles, family owned... Williamsburg, VA
    Quote Originally Posted by ElNormo View Post
    Norman
    There should be metal spring tabs on each end of the switch. They have a habit of falling out when the switch is removed. Without them, there is nothing to hold the switch in place. If you lost your spring tabs, you may have to source a new switch as they're not available as a separate item as far as I know. HTH
    Jan 2005
    Williamsburg, VA
    Quote Originally Posted by Rus View Post
    Very interesting... yes, I'll bet mine fell out!
    Norman
    Bend a piece if spring metal and put it in.
    I used another clip from the headliner clips and filed it to fit. Any piece of spring type metal can be filed to fit and it holds.
    Looks into your junk electronic parts box and see what you have to make it fit.
  1. Rear window switch - free to a good home
    By ElNormo in forum 5 Series BMW
    Last Post: 11-18-2008, 09:24 PM
  2. Rear window switch bulb replacement - how to...
    By g7syw in forum 5 Series BMW
    Last Post: 08-06-2007, 05:12 AM
  3. remove rear side window switch?
    Last Post: 12-17-2006, 08:30 PM
  4. Rear Window Switch Problem
    By Brett619310 in forum 5 Series BMW
    Last Post: 04-19-2005, 12:37 PM
  5. WTB: Good used window switch
    By JonE in forum 3 Series BMW
    Last Post: 10-11-2004, 11:25 AM
