I had the same with my driverdoor, I changed the actuator and it went away!
My car developed a weird door lock issue. When I lock the door, it locks and then it unlocks. If I lock again, it locks fine the second time. It does this with remote or from the door. I already tried disconnecting the battery (thinking maybe it will reset something) but still the same issue. Any idea what it might be?
RICK
BMW 1995 525i (Alpine White)
It can also be the trunk lock. I suppose even the hood lock. What the system is telling you by unlocking like that is that one part of the locking system isn't locking.
Try locking everything and then try opening things until you find out what's not locked. Might very well be the trunk since you had your trunk harness wires break. Might be more damage that you didn't notice back there.
Carefully watch the door locking pins, the one that doesn't work will not go down, it happens quickly so watch closely.
I would press the button, then it would chirp and try to lock, then pop up again upon another chirp almost instantly....mine was the passenger door actuator and it was about $75 from BMA.
Hope you find it easily.
JR
The front door panels are just a little more complicated than the rears. Removal is documented throughout the web and there is even a panel removal procedure on Bruno's site which has migrated over to Wikipedia.
Once the panel is removed, it takes a little fiddeling to get the actuator out and back in place, at least it did me. I tested it to make sure everything worked before putting it all together, even set the alarm off a couple of times. =) It helps to have a telescoping mirror and good focused lighting that doesn't blind the installer. Pay close attention to how the old actuator is mounted and the routing of cables involved.
It took me a couple of hours, start to finish. Don't be in a hurry and don't allow yourself to be disturbed, and everything will go just fine.
JR
Thanks. But it does lock all doors and trunk or unlock. I think the problem is the trunk. Maybe that wire harness issues for the trunk has created this problem. I manually locked the trunk with the key and tried locking and unlocking with the remote and it started go. It will lock and unlock three time now if I leave the truck key position to lock.
RICK
