Results 1 to 10 of 10
Thread: Trunk hinge wire harness issues... Anyone else had this issue?
    Windy City
    Default Trunk hinge wire harness issues... Anyone else had this issue?
    There is a wire harness that runs from the truck lid and runs along the hinge. When you close the trunk, the cable harness gets pinched. Do to the age of the car, cables start to break by being pinched (open and closing of the trunk). Some of the wires have 12v for the rear brake lights. Noticed this when I started to have random rear brake light failures. Has anyone else have this issue? I would think this would be a common problem by the way it was designed. I just cut the cables several inches between where it was pinched and replaced it and made the cables little bit longer. I used solder and shrink tube and wrapped it with cable tape (fabric kind).
    RICK
    BMW 1995 525i (Alpine White)
    very common problem, have to repair a few on my own soon.
    May 2006
    NH
    +1.... splice and splice again.. may be best to just get some wire and butt plugs and go to town.. give each wire an extention segment ... what else are you going to do? Replace the entire harness?
    1995 540i Manual build 1/95
    Long Beach, CA
    I need to get back in there again.
    Wellington,New Zealand
    also caused by the design of the plastic sheath of the hinge and the fact that the last cable tie by the hinge doesnt allow the cable to flex much .I took the last cable tie off and shortened the pastic sheathe to allow cable more room to flex(ie not bed it in such a tight radius)
    Mar 2004
    Yep, been there done that...
    For years thought my rear trunk was being locked - one day checked and it wasn't! Found the frayed wires and fixed them (solder, splice, everything nice)
    Scott
    1995 BMW 525i w/139K miles, EAT Chip - (Gone)
    07 525i 22K, 07 328xi (41K)
    1982 Mazda RX-7 w/147K miles (Back again!)
    croatia, zagreb
    i had that issue as well. simply take some time, replace all wires
    Jan 2008
    Sweden
    Welcome to the club!
    Windy City
    I removed the cable tie clip that's right behind the hinge and move it. I noticed there is another hole for the cable clip just several inches from the original place. By doing so, it does give more flex to the cable harness. Not sure if you did the same thing but seemed be much better there than the original hole for the cable clip.
    Quote Originally Posted by Paul in NZ View Post
    RICK
    El Paso TX
    every e34 will have this happen at some point.
    just be glad it isn't a TOURING!!!
  1. Source for tail light wire harness pinout?
    By SnakeyesTx in forum 5 Series BMW
    Last Post: 05-27-2008, 07:31 PM
  2. Touring rear wire harness
    By ScottyWM in forum 5 Series BMW
    Last Post: 12-28-2007, 07:48 PM
  3. Radio wire harness clip
    Last Post: 12-26-2006, 07:59 PM
  4. trunk hinge wires
    By 1995 525i in forum 5 Series BMW
    Last Post: 12-22-2005, 05:10 AM
  5. 9005 to H1 Wire Harness
    By bimmer2u in forum 7 Series BMW
    Last Post: 12-07-2005, 08:50 PM
