Results 1 to 5 of 5
Thread: Throwing Code 1222
    May 2008
    Enumclaw, WA
    Default Throwing Code 1222
    Hello,
    My check engine light just started flickering on and off and I did the stomp test and It gave me code 1222. Is the O2 sensor the likely cause on a car with 155,000 on it and with the maintenance bars on the dash down to yellow? The engine runs fine and doesnt seem to change when the light comes on. Any other causes?
    Dan Lafley
    95 530i
    Mar 2007
    Liverpool UK
    Quote Originally Posted by Golgade View Post
    Hello,
    Dan Lafley
    95 530i
    If the o2 sensor is good a vacuum leak can throw that code... ???
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    hahaha the season has begun. Replace all intake gaskets including the rear PCV plate and front plate gasket, reboot the computers and good to go.
    May 2008
    Enumclaw, WA
    I just took off the plastic intake tube that goes from the air cleaner box to engine to look at the thermostat a few days ago and from what you said it sounds like a leak from there could do it. So hopefully I just put them on wrong.
    Dan
    good luck I hope so, similar things have happened but not mainstream.
  1. got code 1222, what should i do fist?
    By gsotis in forum 5 Series BMW
    Last Post: 07-21-2008, 06:51 PM
  2. Error code 1222
    By nmwaldron in forum 5 Series BMW
    Last Post: 09-22-2006, 05:28 PM
  3. more help rough idle, CEL, code 1222
    By duckloads in forum 5 Series BMW
    Last Post: 08-29-2005, 05:27 PM
  4. Code 1222 no visible leaks
    Last Post: 12-20-2004, 06:38 PM
  5. M20: Bad ICV consistent with 1222 code? nt
    By Warren N.CA in forum 5 Series BMW
    Last Post: 06-14-2004, 03:53 PM
