Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Heater core leak ..or not
    Ottawa, Ontario, Canada
    My leaked outside. Bypassed the heater core. Lots of info on doing that. No heater though but I don't drive it in the winter.
    Yes, there is.
    Feb 2007
    Just a thought but mine was the Auxiliary blower motor (or something), I could smell coolant when my heater was on but then the car also started loosing coolant at an alarming rate, the leak was from the left side of the bulk head and you could hear it sizzling on the hot exhaust. Turned out it was the blower motor in the engine bay (the one on the left of the engine bay by the bulk head, next to the fuse box - sorry don't know what its called, some of them have a cover on but mine doesn't). The inside of the blower is made of plastic and it had just broken away. Anyway while it was on its way out you could smell coolant but there was no noticeable leak. Maybe someone knows what I'm on about and can add a name to my useless description!
    The good news is it was cheap to sort out which is rare! Are you loosing any coolant?
    Wichita, KS
    Default heater control box
    FWIW, also check around the heater control box mounted on the firewall with all the coolant lines. I'd had a persistent smell & seep when I bought the car from my dad, and ended up pulling the box apart and fixing several o-rings in and around the impeller for the coolant. It was seeping during operation, and dropping out the bottom. I was hard to detect at the time because the car was also seeping the power steering fluid. Messy.
    May the Schwarz be with you...
    The o-rings could be weeping a bit.
    Like Jeff says, not until something is wet will I go poking around in there.
    IIR, the heater box has a drain that exits via the tranny tunnel. You shouldn't see water until its REALLY bad.
    I need to do mine. Have all the parts but have put the job off for a long time. Under the dash is not my favorite place to squeeze my 6'1", 195lb frame.
    Bellevue WA
    86 Porsche 951 - Track Toy
    Apr 2005
    Canada
    Default Could you do me a favor ?
    Quote Originally Posted by Kibokojoe View Post
    Over the past year when ever I turned on the heater I smell coolant. Today I removed the console, dash components and removed the cover on the heater core. Now I can see the heater core but there are no visible leaks. I am running the engine and I have both thermostats set on high. I guess there is a chance it could be leaking on the other side of the core but shouldn't I see coolant dribbling from somewhere. Sure would hate to drop another $200 bucks into fixing something that is not broken. Any suggestions?
    Having the best possible view of the heater box (everything in front removed), could you take for me 1 ou 2 pictures of a particular step motor fixture, the one behind the OBC, located in the right upper part of the heater box just, it is driven by the thumb wheel in the center of the dash. The plastic fixture of mine is broken i improvised a new fixture working under the dash only through the right footwell. What i am seeking is how exactly this set motor is fixe to the plastic heater box. Thanks
  1. Heater Core - Coolant Return Hose Leak
    Last Post: 07-17-2008, 05:10 PM
  2. Coolant leak rear of heater core??
    By Wallabee in forum 5 Series BMW
    Last Post: 06-10-2007, 06:32 PM
  3. Heater Core Leak
    By slip in forum 5 Series BMW
    Last Post: 01-21-2006, 04:09 AM
  4. Replies: 3
    Last Post: 04-12-2005, 01:51 PM
  5. Small coolant leak in heater core
    By Loke in forum 5 Series BMW
    Last Post: 06-22-2004, 05:14 PM
