Results 1 to 10 of 16
Thread: Heater core leak ..or not
    Jan 2007
    Dayton Ohio
    Default Heater core leak ..or not
    Over the past year when ever I turned on the heater I smell coolant. Today I removed the console, dash components and removed the cover on the heater core. Now I can see the heater core but there are no visible leaks. I am running the engine and I have both thermostats set on high. I guess there is a chance it could be leaking on the other side of the core but shouldn't I see coolant dribbling from somewhere. Sure would hate to drop another $200 bucks into fixing something that is not broken. Any suggestions?
    Quote Originally Posted by Kibokojoe View Post
    Obvious heater core leak. It dont take much for the smell. On mine it's okay unless I rev the gears out, then it smells very strongly. Defrost doesn't work unless I turn the AC on. I am not going to change mine out until it sprays water on the windshield and my shoes.
    Jan 2007
    Dayton Ohio
    Default gif is funny
    Your gif is great. Are they having a good time on our taxes?
    You really need to search for the leak... it can be outside in the engine compartment. I am in the same boat as you are.
    May 2006
    NH
    Could be a pinhole in the core on the back side which you can't see when its in place and mostly evaporates before becoming a dribble.. If Antifreeze is lethal to drink how good can it be to inhale the fumes for a year?
    1995 540i Manual build 1/95
    Gee... I think I have been inhaling this stuff for 9 years.
    Jan 2007
    Dayton Ohio
    And you are normal... right?
    LOL... maybe that's why I am a little bit kooky. Seriously, I do want to get to the bottom of it... I am losing coolant all the time.
    Jan 2007
    Dayton Ohio
    Wonder if there is a drain hole on the bottom of the heater core box?
    Yes, there is.
  1. Heater Core - Coolant Return Hose Leak
    Last Post: 07-17-2008, 05:10 PM
  2. Coolant leak rear of heater core??
    By Wallabee in forum 5 Series BMW
    Last Post: 06-10-2007, 06:32 PM
  3. Heater Core Leak
    By slip in forum 5 Series BMW
    Last Post: 01-21-2006, 04:09 AM
  4. Replies: 3
    Last Post: 04-12-2005, 01:51 PM
  5. Small coolant leak in heater core
    By Loke in forum 5 Series BMW
    Last Post: 06-22-2004, 05:14 PM
