Just did mine 2 weeks ago. Bentley manual states the M60 coolant capacity is 12.5 liters (13 qt.) and is self bleeding.
Hello,
I tried looking through the forum for where the coolant change plus is but I just couldnt find it.......so where can I find that bad boy? And how much coolant do I need to buy for a 530i?
Dan
95 530i
There is a drain plug in the radiator and on the engine block. I believe there are actually two on the block, one on each side behind the exhaust heat shields (aluminum sheet metal). I only drained coolant from the right side and the radiator.
after you flush it all out add 50% of the coolant before you add water or else you may have a weak mixture from water remaining in the block.
You know I have been blindly filling this car with more and more distilled water as the old coolant leak away.....Sounds like that was a pretty poor choice. Why do you need such a careful mixture of coolant to water?
Dan Lafley
95 530i
Freeze protection mainly... or it will crack your engine block and radiator on super cold day.
