Results 1 to 10 of 12
Thread: M30 lifting points
    Nashville, TN
    Default M30 lifting points
    Where does one lift an m30 out of an e34? Going to tackle an oil pan gasket soon - need to know where to hook on to.
    Derek A.
    90 535i 5 Speed - Style 5 17"
    Sep 2007
    Melb, Australia
    Lift from the top?
    There are 2 points; the front one is above the water pump. The rear is in a dicky spot above the starter motor.
    The rear spot is part of the iron block. The front spot is like an aluminium bracket which I don't trust all that much.
    Ken, from Melbourne AUS.
    '89 535iA with a 5 speed swap.
    That aluminium bracket is even enough to lift a V12 M70 engine, but that is not much heavier than M30, because the engine is basically light weight metal. Here pics from my parts engine M70, you can see where you can fix it
    http://s71.photobucket.com/albums/i1...ramhackzn4.jpg
    Sep 2007
    Melb, Australia
    Ah ok. When I lifted my engine I didn't lift it from above (like in the picture) more like pulling it back. It bent a bit but I bent it back. But I learnt from it
    if you want to lift it out from the top like I did with tranny attached: then remove the hood, radiator and also the radiator brackets and all parts in the front like the lights and the complete section in front. On my E32 all is fixed by bolts there except the lowest portion in front. Then you have space enough to pull out, because you have to pull forward and also a bit upwards to get the engine over the area where the engine mounts are usually fixed. If you lift too high, the tranny will touch in the area of the fire wall. So rear part down and front part up as shown in the pic.
    Nashville, TN
    I just need to life enough to get the oil pan out. But certainly don't want to rip anything up in the process. Does loosening the tranny mounts help to get the motor to lift a little higher ?
    Derek A.
    Quote Originally Posted by Derek A. View Post
    If all you're doing is lifting a bit to gain access for pan removal, use the aluminum bracket at the front of the engine. I don't have an M30, but according to pics I've seen it should be near the water pump, can't miss it.
    And yes, removing the nuts from the bottom of the trannny mounts may help, but you'll be limited by the tranny bell housing or shift linkage hitting the body.
    Goood luck with it,
    Dave
    Better off dropping the suspension and working from below.
    Nashville, TN
    I have heard two different stories. Some can get the oil pan out by just lifting the engine - others have had to drop the cradle. Not sure what the differences are in technique.
    Derek A.
    Sep 2007
    Melb, Australia
    You'll have to lift it pretty high. You may have to remove everything connected to the engine, air, oil, water etc. I tried doing mine by lifting from undernieth but I couldn'r get high enough the block was hard up against the firewall. I just remembered I made a post about this.
    http://www.bimmernut.com/forum/showt...m30#post307832
    Good luck.
  1. Dash lifting in corner
    By HIe34 in forum 5 Series BMW
    Last Post: 01-12-2007, 02:57 PM
  2. jack points...
    By 632 Regal in forum 8 Series BMW
    Last Post: 12-31-2006, 06:13 PM
  3. Oxygen sensor test with out lifting the car
    Last Post: 11-14-2006, 09:55 PM
  4. jacking points
    By broadie777 in forum 5 Series BMW
    Last Post: 07-03-2006, 06:19 PM
  5. Lifting the auto shift cover
    By Airborne001 in forum 5 Series BMW
    Last Post: 06-21-2006, 01:57 AM
