Results 1 to 4 of 4
Thread: e34 auto and manual pedal boxes...
    Default e34 auto and manual pedal boxes...
    How are they different from e28 pedal boxes?
    I am about to do my second auto to manual swap in an e34.
    Last one was an M50B25, this is an M30B35. I've a kit from an e28 528i- the old 260/5 with the seperate bellhousing. But a few parts clearly don't fit. The clutch resovoir/master cylinder for a start.
    However the pedal box from an e28 certainly won't fit. Now I know that if it was an e34 kit I'd be ok as one has the choice; change the pedalbox over OR add a spring tab and retofot the pedals with the pedals in-situ.
    However... perhaps the e28 pedals can be adapted to the e34 auto pedal box too... Has anyone tried this?
    Cheers, Nick
    El Paso TX
    spend the $15-$30 and just buy one
    and if you have or want telescoping column it needs to be a later pedal box too.
    obviousl if the clutch master doesn't fit the that is jsut another modification to make... and then... and then...
    it's a good way to go bald for no reason when 34 boxes are so cheap with the pedals already hung, masters still in so the hardware is retained... etc.
    also a good way to turn a 45 minute swap into an all weekend ordeal.
    Hey Nick, I see you found the swap pieces.
    The E28 pedal box is notoriously weak in the clutch pedal area, check yours for cracks. Even if you could make it work I wouldn't. E34 stuff isn't that hard to find, and as you said a pedal can be added.
    I hesitate to add that I have the airbag column you seek.
    Quote Originally Posted by Ross View Post
    Woah. Thanks Ross, but I sourced a column a little while back now- (didn't see this post). Having tons of trouble finding a manual pedal box though... (bump they are very rare in Oz.
    Just hope one of the wreckers will get back to me- (they don't like posting o/s)
  1. Replies: 7
    Last Post: 06-24-2008, 08:23 PM
  2. Auto or Manual?
    By 94_e34_525i in forum 5 Series BMW
    Last Post: 09-22-2007, 08:53 PM
  3. wtb manual pedal box
    Last Post: 05-24-2007, 05:37 PM
  4. auto or manual?
    By bullyd in forum 5 Series BMW
    Last Post: 11-04-2005, 01:20 AM
  5. Auto To Manual
    By ZimZimmer in forum 5 Series BMW
    Last Post: 03-12-2004, 09:51 AM
