Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
Thread: Best "low beam" out HID solution?
  1. #21
    Feb 2007
    GreenHills East-Philippines
    Quote Originally Posted by Qube View Post
    Get a proper set with low beam error support... or just wire a resistor pack in parallel.
    For example:
    i had one of those before but that thing REAAALLLYYYY gets HOTT
    HID 5000k low 3000k fogs
    dynaudio seps. mc intosh amp
    Race logic TractionControl
  2. #22
    Geez... just make the simple relay circuit and clip it onto your low beam power wire by the headlight. Mine still work flawless after 7+ years
  3. #23
    Lexington, Kentucky
    Good idea. However, I have yet to see a really complete set of instructions on the relay technique. No offense, but "simple" to you may not be so simple to many of us.
  4. #24
    Yah, I know... you really need to know how to wire it up. I made a bunch to lot of people back in 2001-2 when a bunch of us converted to HID. I could dig up the schematic if needed.
  5. #25
    Lexington, Kentucky
    I would like it. Thanks!
    Not sure ddmtuning will really offer a solution. Perhaps others need a good solution as well. I see a lot of issues on the various boards with HIDs and bulb out warnings.
  6. #26
    Aug 2008
    Pennsylvania
    I am doing research right now to solder in a capacitor or diode instead of a bulb or relay. I will post if I come up with anything.
  7. #27
    Dunlap Illinois
    Here's the relay fix like Tiger was talking about. You'll need to study it a bit so you'll be familiar with the procedure. It's really easier than you think.
    http://www.bbesound.com/bmw/hidinstall/
    I used it on my '91 M5 and it worked fine. The McCullogh kit I used on my M540i Sport didn't throw a low beam error.
    Hope this helps,
    JR
  8. #28
    T·O·R·O·N·T·O
    Really though, you should trade it out for a set that negates the warning
  9. #29
    Lexington, Kentucky
    OK, which brand should I buy that will not have the bulb out problem? Or do you mean trade with ddmtuning for another version. This may be what I do. That said, why trade out if the problem is fixed? Even if the fix is a kludge.
    BTW, with my fix, no wires were cut Everything can be returned to stock in 30 minutes.
    Note: I may make a version that is more elegant-sockets for bulbs in a sealed box. I also see no reason for fuses or relays on this sort of parallel circuit as each headlight is fused and why would you need a relay as you are not triggering anything.
  10. #30
    Not quite...
  1. HID install works but "LOW BEAM" warning?
    By Guelphguy in forum 5 Series BMW
    Last Post: 04-11-2007, 03:58 PM
  2. Fixed the "Low Beam" error message . . .
    By gale in forum 5 Series BMW
    Last Post: 03-04-2007, 11:07 PM
  3. HID "low-beam warning" relay
    By rockyfeller in forum 5 Series BMW
    Last Post: 10-02-2004, 08:53 AM
  4. Installed HID's- Now "Low Beam" Error Message.....
    By Don McAdams in forum 5 Series BMW
    Last Post: 07-25-2004, 09:45 AM
