Results 1 to 10 of 15
Thread: Heeeeellllp, steeringwheel nut is stuck!
    Jan 2008
    Sweden
    Default Heeeeellllp, steeringwheel nut is stuck!
    Like the header says, the steering wheel lugnut is like welded in.. I canīt get it to release no matter how hard I try and thats VERY hard.
    My current steering wheel is starting to look worn/dull and Iīve got a near perfect new one that Iīd like to use.. But that friggin lugnut is giving me hell!
    Marietta, GA
    Have you tried having someone hold the steering wheel while to try to get the nut off?
    Jan 2008
    Sweden
    Not yet But be sure that I will this sunday!
    Nov 2006
    Mid-Atlantic, USA
    Quote Originally Posted by Bo525i View Post
    Not to point out the obvious but are you using a breaker bar?
    croatia, zagreb
    er....
    guys...
    lock the steering wheel - without the key in....then use breaker bar and it will SURELY get the nut to loosen. then don't forget to give contact, and pull the wheel out.
    That will also ruin your steering lock.
    Nov 2006
    Mid-Atlantic, USA
    Quote Originally Posted by filip00 View Post
    That'll work great if you only want to remove the nut but maybe not ever get the steering wheel off. Is that how you broke the "shift" keys on your Dell?
    Jan 2008
    Sweden
    And thats exactly what I donīt wanīt to do..
    lodge a breaker bar and then reef the wheel to loosen it? turn the right way? lol, good luck.
    Aug 2008
    London, UK
    Hi,
    I would suggest you don't use a breaker bar, but an impact wrench. If like me you don't have a handy air supply you can get an electric one off ebay like this:
    They can supply upto 250 lb/feet and work off of 12v. It can undo wheel nuts from fully torqued with the front wheel in the air .
    Just a thought - is it a left hand thread ?
  1. Removing stuck wheels+stuck lugnuts
    Last Post: 06-02-2010, 09:28 AM
  2. Steeringwheel shakes Left to Right
    By vping in forum 5 Series BMW
    Last Post: 05-04-2008, 03:43 PM
  3. Auxiliary fan is stuck
    By Monastie in forum 5 Series BMW
    Last Post: 09-09-2007, 09:41 AM
  4. A/C Stuck On?
    By ElNormo in forum 5 Series BMW
    Last Post: 04-21-2005, 12:41 PM
  5. help I'm stuck
    By jsvizijr in forum 5 Series BMW
    Last Post: 04-08-2004, 03:41 PM
