Its never raining at realoem
I can't see anything but a water pump and coolant hoses, no intermediate black plastic connection bit. Have a look at the diagram and keep in mind that I don't have a 530.
Dave
Does anyone know what the black part(at least on my car it is black and I think it is plastic but its raining and I dont want to check!) that bolts into the water pump and connects to the radiator hose that goes to the top of the radiator. I have developed a nice coolant leak and I notice a nice crack on that black thing and some leaking is coming from the bottom. So I need a new one of those, is that going to be a dealer part or does would schucks or Napa going to have something like that? And what coolant am I going to need for replacement?
Dan Lafley
95 530i
Dave
*RIP Oskar the DOG*
Sounds like the thermostat cover. In the UK, these are available from some aftermarket suppliers such as eurocarparts.com.
1997 535i V8
............unless you're talking about the thermostat housing, which appears to connect to the lower rad hose.
diagram
Heres one at BMA for $15
Dave
*RIP Oskar the DOG*
This is the best picture I have. There is nothing connected to the coolant hose to the radiator other than the inlet and the outlet.
'01 540it, 6/01
'03 325i 5 speed, 9/02
'10 535ix. 9/09
'10 mini 6 speed
'15 mini countryman 6 speed
Sounds exactly like the thermostat housing. The plastic one will leak as it age. Get the metal one.
Thats it, the black coupling thing, but I suppose calling it a thermostat housing would make it easier to find.
Thanks!!!
Dan
Oh I forgot, I am going to change the coolant too, What kind of coolant am I "supposed" to use, and where is the drain plug.
Thanks!
Dan
I probably need to buy a new Thermostat and the housing I would imagine, but anything else? I hope I dont need a new water pump.
Dan Lafley
95 530i
Do a search fro "coolant" and have fun deciding what to do.
If you don't have hours of your life to spare and you live relatively close to a dealership, go buy some 'blue' stuff from them and forget about it.
Take a look at your hose clamps in case they need replacement. Someone else can tell you where the drain plug(s) are on the M60. I have no clue where the block drain is located.
Dave
*RIP Oskar the DOG*
