Results 1 to 2 of 2
Thread: Rough idle problems PLEASE HELP
    Apr 2008
    pa usa
    Default Rough idle problems PLEASE HELP
    My e34 525i is idling rough when i come to a stop. fluxuating from 500rpm to 1000rpm the lights dim and it sometimes almost stalls on me. I heard something about a c194(or something) connector that if it got wet and corroded could cause these situations. Could anyone confrim or give any advice for this problems. thanks in advance.
    Quote Originally Posted by bmw_525i View Post
    Your ECU is trying to adjust for an air leak, a bad sensor or bad combustion. Either that or the ICV is sticking and the ECU is unable to control idle properly as a result. Pul the ICV, check oit works smoothly and check for obvious things first; air leaks, hoses, seals and connections under the intake manifold that have cracked or become loose and are letting air in. Search this forum if you don't know where to start. Then check plugs, temp sensors, injectors, O2 sensor, etc. Good luck and post back when you find the root cause. The symptoms are often confusing
  1. Very rough idle, 92 525
    By aecs8284 in forum 5 Series BMW
    Last Post: 06-20-2008, 11:07 AM
  2. Rough Idle
    By hinchcliffe in forum 5 Series BMW
    Last Post: 08-27-2006, 10:12 PM
  3. M60 3L rough idle , white smoke at start ,and more problems
    By Brent in NZ hartge 535i in forum 7 Series BMW
    Last Post: 04-08-2005, 11:07 PM
  4. M60 3L rough idle , white smoke at start ,and more problems
    By Brent in NZ hartge 535i in forum 5 Series BMW
    Last Post: 04-08-2005, 10:52 AM
  5. Having Problems With A Rough Idle
    By SIXPACKDREAMER in forum 5 Series BMW
    Last Post: 03-11-2004, 03:02 PM
