Quote Originally Posted by HIe34 View Post
I'm bleeding my coolany system and when I close the bleed screw on the thermostat, my check engine light is coming on (solid). When I open the bleed screw, it goes off.
My temperature needle is closer to the cold blue than the middle which is also kind of weird since about 10 minutes before that, it was 3/4 of the way to Red.
Curious about the check engine light and is my thermostat going?
So yes this bleeding thing has been absolutely a blast..but I digress, went to add more coolant and there is a yellow/orangish plug floating in it. I'm assuming this plug goes at the bottom of the expansion tank and pressure blasted it out, can this plug be plugged back in or am I looking at a new one? Is that sold separate (i can't tell on realoem) or do I need a new expansion tank.
My problem now is that since that is dislodged, there is no pressure in the expansion tank and so when the coolant starts boiling it is pouring out of the expansion tank.
Any advice is appreciated.
