Results 1 to 5 of 5
Thread: weird display
    Default weird display
    is this normal?
    when i turn the ignition to position 2 this is what it displays:
    BMW NR 8359205
    CODE NR 00000
    K - ZAHL 7296
    F. G. NR BJ76472
    SW. VERS 0.97
    AND. INDEX 23
    Check Control
    Owner's Manual
    and then all my guages go (tach, speedometer, mpg, temp)
    Can someone please tell me what's going on? Thanks a lot!!
    Edwin
    Mar 2004
    This sounds like the instrument cluster self diagnostic test. Check to see if one of the black push buttons on the instrument cluster is stuck.
    Paul Shovestul
    Quote Originally Posted by nuwde
    is this normal?
    BMW NR 8359205
    CODE NR 00000
    K - ZAHL 7296
    F. G. NR BJ76472
    SW. VERS 0.97
    AND. INDEX 23
    Check Control
    Owner's Manual
    Edwin
    netmgr Guest
    Default guess
    id guess one of the dash buttons is stuck in??? and its going into test mode when you turn on the ignition?
    darren
    it doesn't seem stuck...meaning i can push it in and comes back up. there are only 2 right? one for the odometer, and the other is the check control button. anything else i can try? thanks a lot,
    edwin
    Apr 2004
    Something I found helped when my cluster was playing up was to remove all the fuses relating to the instrument cluster. Then put them back in again.
    I would also try turning the car to ign II then holding the CCD button down and if a dotted box appears in the display when you hold down the button then you know its not the button thats the problem
  1. CEL / dashboard display
    By timandbim in forum 5 Series BMW
    Last Post: 08-27-2007, 12:23 PM
  2. OBC display isn't illuminated
    By OSUBuckeye59 in forum 5 Series BMW
    Last Post: 01-08-2007, 10:22 AM
  3. Mileage display
    By richie535 in forum 5 Series BMW
    Last Post: 11-06-2006, 12:31 PM
  4. OBC Display
    By slupregime in forum 5 Series BMW
    Last Post: 06-12-2006, 08:02 PM
  5. Red dot on mileage display??
    By GM525 in forum 5 Series BMW
    Last Post: 03-08-2005, 08:40 AM
