When I remove the kickpanel and seats out of my E34 I didn't break any clips. You just have to be careful because the door sill clips can break.
When I bring my car to have the floorboard welded in on Monday I will be removing the interior myself at the shop. Center Console,seats, kick panel but I've never pulled up the door sill. But Never having pulled the carpet up I figured I ask weather I should come prepared in case there were moldings or maybe the door sills may have clips that might brake.. Just trying to cover all my bases before I start this ..thanks
1995 540i Manual build 1/95
All around the gas pedal. The pedal will now fall right thru and sit on the exhaust pipe... I fashioned a little prosthetic out of some sheet metal so I can drive it but will get it ground and have a new hunk of steel MIG welded in Monday.. I suspect that the leaking AC condensation hose I Ignored may have contributed along with living in the Northeast ,all the salt in Winters ..whatever the cause it'll be fixed..
Ewwwww. Better check mine.
*RIP Oskar the DOG*
If it's anything like the wreck we salvaged, you won't be able to get the forward carpet out without removing the heater unit. I recall that you can carefully cut around the heater box and you should be able to conceal the cut under the console.
Bellevue WA
86 Porsche 951 - Track Toy
