Results 1 to 10 of 13
Thread: Urgent: Manual valve(shifter) seal M50
    Aug 2008
    Pennsylvania
    Default Urgent: Manual valve(shifter) seal M50
    I apologize in advance for making threads, but I need help. I keep replacing the seal on the manual valve body or shifter because everytime I install the new seal, the inner lip on the seal gets caught on the square edges of the shaft and pushes the seal outward. This is the 4th seal that I am on and this time I am trying a new approach. I had an idea of making some type of sleeve that would fit inside the seal and go over the shaft so the inner lip would stay aligned correctly, but that didn't turn out to be the way I planned.
    So now I am stuck. I have the old seal out, but I cannot get the new seal in correctly. How am I suppose to get in correctly? Is there a special tool other than the BMW tool to get it in?
    Thanks.
    Benneton (United Colors of)
    are you following the bentley procedure or the bmw electronic repair manual procedure? could you take a picture for us? i thought that your other thread said that you accomplished this already.
    Aug 2008
    Pennsylvania
    I did, but today I saw that the seal is screwed up.
    so you're trying to get the seal on over the shifter shaft? i take it you didn't take the valvebody out to replace this seal? if that is the case, did you lubricate the seal with vaseline or atf before you tried to drive it on?
    Aug 2008
    Pennsylvania
    Quote Originally Posted by ryan roopnarine View Post
    Yes I did lubricate the seal. I just picked up a copper pipe from Lowes that is slightly bigger than the shaft. I will make a sleeve out of it and hopefully it will do the trick.
    Aug 2008
    Pennsylvania
    I could not get a picture of the seal because its hard to see. When the seal is out of the transmission, the inner lip faces inward if you place the seal the way it would be in the car. Once you start to press it in, the seal pushes itself outward(towards the outside of the transmission).
    My sleeve idea did not work. So I used some petroleum jelly and drove it in the best I could. It looks to be squared away, but the previous one looked fine too until it started to leak. If this one leaks I will just have to drop the sump and remove the valve body.
    I also checked the fluid and had to add half a quart of ATF. This is not that bad considering I did a filter and fluid change a month ago and I have not added any fluid since.
    Aug 2008
    Pennsylvania
    The seal still leaks. I guess I will wait till it leaks a lot and I will pull the oil sump and remove the shaft. Is it possible to remove the shaft from inside of the transmission or do I have to lower the transmission?
    Sep 2007
    Seattle, WA
    Have you been putting the seal in the right way? Are you sure it's not supposed to be facing the other way?
    Aug 2008
    Pennsylvania
    I am pretty sure I have been putting the seal in correctly because of the way the seal is. The inner lip on the seal faces towards the inside of the seal, and when I slide it over the shaft the sharp edges on the shaft cause it to flip the opposite direction. I have tried using tape, making a sleeve, nothing works.
    I am trying to find the BMW tool with the part number 24 5 200 but without any luck. I looked at the manual about removing the shaft and it looks like it slides outward away from the transmission. So this means I would have to lower the transmission.
    Sep 2007
    Seattle, WA
    If the shaft it causing the seal to flip to the opposite direction would trying to put it in the wrong direction cause it to flip over to the proper way? Without seeing the seal/shaft etc. I can't say much else as I don't know what's exactly going on. But trying to put the seal on wrong might work if it flips itself over upon insertion.
  1. Desperate need of a manual shifter console surround...
    By shrike071 in forum 5 Series BMW
    Last Post: 04-02-2007, 08:09 PM
  2. Replies: 8
    Last Post: 11-19-2006, 02:43 PM
  3. Manual shifter vibration?
    By gale in forum 5 Series BMW
    Last Post: 11-05-2005, 12:42 AM
