So recently, my windshield washer pumps died ( both main and intensive ).
I replaced them, and noticed my headlight ones died too.
I've checked all the fuses (front and back), checked the RM module under the seat in the back, everything LOOKS fine.
I checked the wiring as well as i could, nothing looked to be frayed or damaged.
I cannot figure out why they wont work![]()
"Uncle" Phil C
2011 Kia Optima EX-P.
Former owner of a 95 525i 5spd. "The GQ" aka A Shark in sheeps clothing
03 R1150RT 6spd. "DaRTth"
00 R1100R 5spd. "LeRoy"
that's weird that 2 pumps died at exactly the same time. so you know different models have different tank setups, i don't see any info on your car. in mine, the headlight washer pump is a second pump mounted on the main reservoir at about the same level as the level sensor while the intensive cleaner is mounted at the back (towards windshield) of the engine compartment. the pipes and fixtures inside the bumper can leak liketoo.
Mine is mounted as the main has it's own tank on the right front. The intensive is a separate tank on top of that with it's own pump. And then the headlight is on the left side with it's own pump.
I know the lines aren't leaking. I've looked at that. I tested the plugs with a multimeter and didn't get anything. All fuses are okay. Is there a relay for the headlight cleaners?
i think the wipers have their own relay.All mine work but the intensive wash sequence doesnt.
Gone but not forgotten
So now the switch on the steering column is messed up... I can push it in, but it doesnt do anything anymore.
So I'm gunna replace that and see where it gets me. I really want my headlight cleaners for the winter![]()
