Results 1 to 5 of 5
Thread: Newbee Question - Jack stand position
    Apr 2004
    Philadelphia, PA
    Default Newbee Question - Jack stand position
    I've got everything I need to do my yearly maintenance and I've jacked my '95 530i up - my stupid question is - where is the best place to locate the jack stands. I'll do the rear first (fuel filter) and then the front later so I need both positions. I'm sitting here waiting to get started so any quick replies would be appreciated. THanks!
    Default Check here on Don Gale's site.
    Here
    Quote Originally Posted by 530iBall
    i still don't get the problem some people have with jacking on the front crossmember and diff, these are the most strong and securely mounted components of the car, i wouldn't lift directly from the rear crossmember from the stand point of over stressing the old subframe mounts
    Unregistered Guest
    I have tried lifting from rear crossmember one time and that would be the last time. That caused a slight crack in crossmember. I welded the crack but decided to get a new one. Expensive mistake. Last time I'm going to lift from crossmember.
    another reason for not jacking the rear crossmember, it does span the entire width of the car with no support in the center
    Quote Originally Posted by Unregistered
  1. Advice on jack stand placement
    By David P in forum 5 Series BMW
    Last Post: 11-18-2007, 09:14 PM
  2. Question about Crank Position Sensor
    By Dave M in forum 5 Series BMW
    Last Post: 04-19-2007, 04:03 AM
  3. Jack question again
    By Alpinewhite in forum 5 Series BMW
    Last Post: 07-23-2006, 07:55 AM
  4. Jack and Jack Stand Positions...
    By dternst in forum 5 Series BMW
    Last Post: 02-08-2005, 01:54 PM
  5. Throttle Position Sensor question
    By phildg2000 in forum Electronics & Lights plus A/C
    Last Post: 07-24-2004, 07:50 AM
