I just found a oil pump from a 93 740i that I think will fit, am I correct in thinking this? Anyway to double check?
Dan Lafley
I just dropped my pan on my M60, to find two of those 10mm bolts, one of those 13 mm and THE NUT OF THE OIL PUMP SPROCKET. So I was happy i pulled the pan. I go to put the nut back on, sheared bolt right off the oil pump with me just hand tighting it. So upside I avoided a major Problem, downside, I need a new oil pump. Does anyone have one or know where I can get one? Or can I replace that happy little bolt or what ever you want to call it that the sprocket sits on?
PLEASE HELP!
Dan Lafley
95 530i
Dan Lafley
bookmark this link, you can make a cross reference check with the part number and that tells you this
http://www.realoem.com/bmw/partxref....=on&showeur=on
http://www.realoem.com/bmw/partxref.do
use the search, find the part number, then make x-reference
http://www.realoem.com/bmw/select.do
