Results 1 to 7 of 7
Thread: e34 540 with autotrans won't pull to redline
    Apr 2008
    jax, fl.
    Default e34 540 with autotrans won't pull to redline
    1995 540 150,500 miles i cannot get the car to pull to redline in anyother gear but first. maybe clogged cats, bad coils, i don't have any other ideas?????
    WHATEVER YOU DO, DO IT RIGHT
    Automatic? It sounds like valve body issue if your tranny is automatic. I would definitely rebuild the valve body before considering any other issue. Worn checkballs would do a varying degree of reverse gear engaged.
    I'm with Tiger on this, the more you flog it the more it burns the reverse clutches resulting in a very expensive testing routine. What are any other symptoms? Does it seem like the brakes are on when gassing it? If so it's the trans. Be careful with this testing your doing.
    Sep 2007
    Seattle, WA
    Have you tried disconnecting the negative battery cable for a half hour or so then re-connecting it?
    What RPM does it hit/stop at?
    And is the tranny noisy (does it whine?)? If it's noisy it's low on fluid which could make it act odd.
    Apr 2008
    jax, fl.
    Default new exhaust installed
    Quote Originally Posted by gpljrrr View Post
    i installed new exhaust this evening cats were melted, broken, and pieces found there way into premuffler and final muffler. now all freed up, i used
    1- duel 2.25 inlet 3" outlet at the downpipes with flanges at the outlet side (for driveshaft removal access) then 3" 14 ga. aluminized piping to a 3" inlet and 3" outlet (at factory final muffler location) and ended with a 3.25 slash cut rolled end (apporx. 45 deg) tip looks good, perf. awsome revs to redline as if i installed a lightened flywheel on a manual trans. car car simply pulls hard from idle to 2800-3000 rpms then pulls like a 727 at takeoff to redline just to fast for all but experienced drivers.
    what made you suspect the cats in the first place?
    Apr 2008
    jax, fl.
    150,000 miles and internal combustion engine is like an air pump if you got good flow in has to go out somehow. and did not seem to be ignition or fuel only one thing left exhaust.
  1. autotrans fluid change
    By 2fast in forum 5 Series BMW
    Last Post: 09-26-2009, 09:38 PM
  2. Autotrans advice please
    By ss2115 in forum 5 Series BMW
    Last Post: 09-17-2009, 01:33 PM
  3. AutoTrans Fluid Change
    By PeterInSTL in forum 5 Series BMW
    Last Post: 09-10-2005, 04:24 PM
  4. AUTOTRANS Question 95 525i
    By jmr898 in forum 5 Series BMW
    Last Post: 07-06-2005, 06:11 PM
  5. autotrans wiring
    By crunchy in forum 5 Series BMW
    Last Post: 03-16-2005, 09:46 AM
