First of all Hi & welcome!!!
Did u do the suspension work yourself? Were the springpads replaced with the shocks & springs? Are the springs seated correctly?
Might also be worth checking the big bolt that holds the bottom end of the strut on is torqued correctly... And spray some lubricating grease on the hole that bolt goes thru too, it can sqeak. Oh check the handbrake shoe isn't rubbing on the hub even with the lever all the way down, I've had terrible troubles with mine and it caused a hell of a sqeak! I had to remove the brake disc to discover my problem was fairly bad... If u need more details just ask!!!!! HTH.
