Results 11 to 20 of 29
Thread: Synthetic Conversion
    this is good news, I will look for this on the weekend. Do you have any links regarding the 100% synthetic area?
    Quote Originally Posted by shrike071 View Post
    M1 "Turbo Diesel Truck" 5w40 is still 100% synthetic and is a near-perfect oil with a fantastic additive pack.
    Honolulu
    I still use Mobil 1 15w50.
    Bob you live where Banana and Coconut trees are the norm... LMAO Here was our 3rd day above freezing in 2 months so that would be a bit thick right now.
    Quote Originally Posted by Blitzkrieg Bob View Post
    Nov 2006
    http://www.mobiloil.com/USA-English/...uck_5W-40.aspx
    Notice that this is one of the only ones that Mobil will still tout as "Fully Synthetic".
    Also - check out bobistheoilguy.com. There is a TON of good reading on there regarding all sorts of oil and associated tests. The information from this site is the reason I went to M1 TDT.
    The Lotus and Ferrari guys adore this oil, if that tells you anything. With Amsoil being over $9/qt now, this is the way to go.
    Car Info is HERE
    Awesome link! thanks!!!
    For diesel engines, Mobil 1 Turbo Diesel Truck:
    • Meets CJ-4, CI-4, and CH-4
    • Is recommended for diesel-powered pickup trucks built by Ford, General Motors, GMC and Dodge.
    • Meets diesel engine requirements of Cummins, Powerstroke, Duramax and Navistar.
    Nov 2006
    http://www.lotustalk.com/forums/f25/...-oil-ok-62743/
    http://www.bobistheoilguy.com/forums...Number=1144473
    http://www.chargerforums.com/forums/...ad.php?t=55812
    Down towards the bottom - look for "Doug H's" post:
    http://www.boxsterforum.com/forums/p...ad.php?t=11572
    This oil is a well-kept secret of Mobil-1 and the 'Gorilla in the corner' for Amsoil and RP.
    Car Info is HERE
    Feb 2007
    found this link on the subject, has more of the basics (my level), do you ever prime your filter when changing oil? The m60 has a different housing but I guess you could prime it by pouring some directly into it or does this provide no benefit?
    Feb 2007
    Feb 2007
    turbo diesel truck engine oil in a non-turbo petrol car? wow I wasn't expecting that!
  10. #20
    Nov 2006
    The only thing I do in regards to priming, is disconnect the fuel-pump relay and allow the engine to cycle for a while to get the oil running around. In the M5x/S6x series of engines, you can't prime the filter - it simply drains back into the block.
    Car Info is HERE
  1. Proper conversion from Dinosaur to Synthetic Oil
    By ThoreauHD in forum 5 Series BMW
    Last Post: 04-15-2006, 11:46 PM
  2. Replies: 5
    Last Post: 09-12-2005, 06:07 PM
  3. do you use synthetic oil?
    By ve39 in forum 5 Series BMW
    Last Post: 09-08-2005, 10:17 PM
  4. Regular or synthetic oil?
    By ilya in forum 5 Series BMW
    Last Post: 04-25-2005, 08:41 PM
  5. Synthetic oil is wrong for the e-34???
    Last Post: 11-25-2004, 01:53 PM
