Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Dumb oil change question
    Feb 2008
    Bahston!
    Default Dumb oil change question
    This will be my first oil change for the 540. Sorry for the n00b question. Is this the drain plug, directly on the bottom of the pan?
    Much appreciated!
    1995 540i6 - for sale $5,500
    Mar 2007
    Liverpool UK
    Hey there,
    Don't rush into anything because on the m30 (straight six engine) it's on the side of the sump (oil pan)... Difficult to tell from the pic but someone with an m60 will let you know for sure...
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    Feb 2008
    Bahston!
    No rush, probably won't be done for a few weeks anyways.
    All the other cars I've done oil changes for always come off the side so that's why I am a bit weary.
    The manual wasn't much help either.
    But thanks!
    Oldham, England
    Default 540 drain plug
    Dont have a 540 but if that plug is the lowest point of the sump its got to be the drain plug. A sure sign is if its got some silly square drive or torx insert to undo it. The clincher is if you undo it and get covered in warm black stuff
    Looks good to me. the thing that sucks is if the car is on ramps all the old juice wont come out.
    Did you check to see how many oil pump bolts are rolling around in the pan yet? I only had 2. Might want to check that instead of just changing the oil.
    Mar 2007
    Liverpool UK
    Looks like the m60 oil pan is easy enough to drop am I right?
    Quote Originally Posted by e34.535i.sport View Post
    real simple, new gasket for the lower pan and good to go. Why I procrastinated on it is beyond me.
    Marietta, GA
    Yes, the drain plug on the 540 is directly on the bottom of the pan. I found it strange the first time I changed my 540's oil as the drain plug for my 530 was on the side on the pan.
    Yes. You're correct. Oil plug is on bottom of pan.
    530/6? Mine is on the bottom.
    Quote Originally Posted by pgrindstaff View Post
  1. another dumb m30 question?
    Last Post: 01-13-2008, 08:57 PM
  2. A Dumb Question
    By The Melmaan in forum 5 Series BMW
    Last Post: 12-27-2006, 01:59 PM
  3. Dumb Question
    By John B. in forum 5 Series BMW
    Last Post: 10-31-2006, 05:07 PM
  4. Dumb question: How to know when ABS kicks in
    Last Post: 08-16-2006, 04:21 AM
