Thanks. I checked that area and it seems okay. I checked fusible link, it is okay. All the fuses, including under rear seat, is okay. When I put the ignition key to II, I don't hear any humming noise from the trunk, fuel pump area though.
The car was okay until last Monday morning. In the afternoon, it did not start. next day, on Tuesday morning started, and I brought the car to home. I turned off the ignition, and started again, and it was going. When I started again to put it in the garage, it started okay, but died and I pushed in the garage. Wednesday morning, it started okay twice , but did not drive, thinking it was okay. I checked the codes with peake, and got knock sensor, Cyl 4-6 (code 45). Ordered the knock sensor and got it, but did not installed, because it was very difficult to install without taking the intake manifold. I checked again with Peake, no codes. Then batter went bad, and tried to jump start, it did not work (it always cranked). I disconnected battery and charged it and connected back, but there was no check engine light at this time and started getting transprogram message on dashboard. The battery is still okay and I get cranking when I turn the key, but doesn't start.
I cannot see any bad wiring, disconnection. It is very frustrating as I cannot check engine light to stomp test.
Anything else, I should look at it before getting it towed to a mechanic?
