Results 1 to 3 of 3
Thread: Procedure to install a idle control value!!
    Nov 2006
    Default Procedure to install a idle control value!!
    i have a 1991 525i..i am going to install a idle control value this weekend. i need to procedure to do this job!!
    Thanks!
    Donf
    Honolulu
    Quote Originally Posted by donf View Post
    Thanks!
    Donf
    You'll need to remove the airbox, intake boot and various hoses.
    Now comes the fun part.
    You gotta reach under the manifold and remove the old one.
    You can just see what you are doing through the holes between the intake runners.
    Be gentle with the hose and nipple on the manifold.
    Before doing anything, check all the connections on the inside of the underside of the intake. Follow the hoses to them- there are three. Big one in the middle, one at the firewall end feeding the FPR, and one at the front. The o rings on these tend to go, the clips holding them in break... causing leaks which make you think something else (ie the ICV) are faulty... chk these, your connecting hoses for pinholes and cracks... and all the easier to check bits also...
  1. Anyone need/want an M50 idle control valve?
    Last Post: 01-21-2008, 10:19 AM
  2. Lining up control arms on install
    By JMI in forum 5 Series BMW
    Last Post: 06-05-2007, 10:31 PM
  3. Control Arm Install
    Last Post: 11-21-2005, 12:22 PM
  4. Is my Idle Control Valve about to die?
    By George Davis in forum 5 Series BMW
    Last Post: 03-23-2005, 07:39 PM
  5. Idle Air Control Hose
    By jj7 in forum 5 Series BMW
    Last Post: 11-29-2004, 10:07 AM
